Tiva and ChibiStudio
ChibiOS public support forum for topics related to the Texas Instruments Tiva family of micro-controllers.
Moderator: Marco
gsmsby
Postby gsmsby » Sun Mar 01, 2015 10:56 pm
I'm new to chibi. I used to code in proprietary OS (TI - RTOS). Could someone help how to setup the chibi (I'm using chibi studio) to use the TIVA port of chibi which is ported by Marco I believe).
So, assuming, I have download the tiva port via github, what should I do next ?
If i just open the demo project and build it, I got the below errors :
Makefile:79: ../../../../os/hal/hal.mk: No such file or directory
Makefile:80: ../../../../community/os/hal/boards/TI_TM4C123G_LAUNCHPAD/board.mk: No such file or directory
Makefile:81: ../../../../community/os/hal/ports/TIVA/TM4C123x/platform.mk: No such file or directory
Makefile:82: ../../../../os/hal/osal/rt/osal.mk: No such file or directory
Makefile:83: ../../../../os/rt/rt.mk: No such file or directory
Makefile:84: ../../../../community/os/rt/ports/ARMCMx/compilers/GCC/mk/port_tm4c123x.mk: No such file or directory
Makefile:85: ../../../../test/rt/test.mk: No such file or directory
Makefile:198: ../../../../os/common/ports/ARMCMx/compilers/GCC/rules.mk: No such file or directory
make: *** No rule to make target `../../../../os/common/ports/ARMCMx/compilers/GCC/rules.mk'. Stop.
14:33:55 Build Finished (took 646ms)
Thank you
Novita
Marco
Has thanked: 4 times
Been thanked: 11 times
Re: Tiva Support
Postby Marco » Sun Mar 01, 2015 11:31 pm
Hello Novita,
Good to hear someone is trying to use the Tiva port for ChibiOS. :)
The easiest way to start with the Tiva port is by downloading ChibiStudio. The Tiva port is hosted in the community repository of ChibiOS and therefore already included in the community folder of ChibiOS. You can find a demo under ChibiStudio/community/demos/TIVA.
In ChibiStudio go to file->Import->Existing projects into workspace and select a project from the TIVA demo folder described above.
To start your own project just copy and modify a demo project.
Marco
gsmsby
Re: Tiva Support
Postby gsmsby » Sun Mar 01, 2015 11:37 pm
Hi Marco,
Yes, It compiles without error now ! Thanks
By the way, how do I debug the project ?
When I click on debug or run, it says "No binary ...?
and do I use OpenOCD ? over ICDI ?
thank you
Novita
Marco
Re: Tiva Support
Postby Marco » Sun Mar 01, 2015 11:55 pm
Where did you put the ChibiStudio folder?
It should be placed in C:\ so you get C:\ChibiStudio
EDIT
Yes to debug the project you use OpenOCD with ICDI if you are using ICDI, i assume you are using the launchpad.
After you setup the debug interface you have to run the debug configuration.
Marco
gsmsby
Re: Tiva Support
Postby gsmsby » Mon Mar 02, 2015 12:18 am
Yes, That's where I copy the chibistuio.
Everything compiles fine now.
But, I have trouble to run/debug the project.
Could you please give me more detail information on how to setup the debug setting ...
I use launchpad , so yes, I use ICDI. And ICD driver has been installed.
How do I seup the debug interface ?
and what should I set on debug configuration ?
thank you so much Marco
Novita
EDIT
Marco
Marco
Re: Tiva Support
Postby Marco » Mon Mar 02, 2015 12:48 am
Click run>external tools>external tools... And select the OpenOCD with ICDI and select the ek-tm4c123g launch confiruration of OpenOCD. Then start the debug session with the debug configuration RT-TM4C123G-LAUNCHPAD.
Tomorrow i will write a small setup guide.
Marco
gsmsby
Re: Tiva Support
Postby gsmsby » Mon Mar 02, 2015 5:06 am
Hi Marco,
I think that's a good idea.
I tried to debug, but still I got " File not exist" error...
Thank you
Novita
Marco
Re: Tiva and ChibiStudio
Postby Marco » Mon Mar 02, 2015 11:54 pm
Hello gsmsby,
I splitted your posts from the other topic.
I added an initial guide on how to setup ChibiStudio in combination with the Tiva devices here.
Please let me know if you have any issues.
Marco
gsmsby
Postby gsmsby » Tue Mar 03, 2015 11:47 pm
Hi Marco,
I works like a charm !
Thank you
gsmsby
Postby gsmsby » Wed Mar 04, 2015 12:31 am
Hi Marco,
By the way, is there any example on how to use fatfs on tiva ?
I've seen stm32 -fatfs example , but on tiva.
what files need to be included ?
and how to include them ?
I think I know how to use the fatfs once it's setup.
I use fatfs with tivaware and ti-rtos before, so I'm quite familiar with fatfs, I think ...
Thank you
Return to “Tiva Support”
