[INFO] ARM GCC 11.2
Has thanked: 1113 times
Been thanked: 937 times
[INFO] ARM GCC 11.2
Postby Giovanni » Sun Apr 24, 2022 6:46 pm
I tested using the latest GCC from ARM, no revolutionary changes, few benchmarks improved a bit.
10.3.1
*** ChibiOS/RT Test Suite
*** Compiled:     Apr 24 2022 - 19:39:20
*** Platform:     STM32H735 Single Core Very High Performance with DSP and FPU
*** Test Board:   STMicroelectronics STM32H735IG_DISCOVERY
*** Text size:    50712 bytes
*** RO data size: 10476 bytes
*** Data size:    220 bytes
*** BSS size:     5952 bytes
=== Test Sequence 1 (Information)
--- Test Case 1.1 (Port Info)
--- Architecture:                       ARMv7E-M
--- Core Variant:                       Cortex-M7
--- Compiler:                           GCC 10.3.1 20210824 (release)
--- Port Info:                          Advanced kernel mode
--- Natural alignment:                  4
--- Stack alignment:                    8
--- Working area alignment:             8
--- Result: SUCCESS
--- Test Case 1.2 (Kernel Info)
--- Product:                            ChibiOS/RT
--- Stable Flag:                        0
--- Version String:                     7.1.0
--- Major Number:                       7
--- Minor Number:                       1
--- Patch Number:                       0
--- Result: SUCCESS
--- Test Case 1.3 (Kernel Settings)
--- CH_CFG_ST_RESOLUTION:               32
--- CH_CFG_ST_FREQUENCY:                10000
--- CH_CFG_INTERVALS_SIZE:              32
--- CH_CFG_TIME_TYPES_SIZE:             32
--- CH_CFG_ST_TIMEDELTA:                2
--- CH_CFG_TIME_QUANTUM:                0
--- CH_CFG_MEMCORE_SIZE:                0
--- CH_CFG_NO_IDLE_THREAD:              0
--- CH_CFG_OPTIMIZE_SPEED:              1
--- CH_CFG_USE_TM:                      1
--- CH_CFG_USE_REGISTRY:                1
--- CH_CFG_USE_WAITEXIT:                1
--- CH_CFG_USE_SEMAPHORES:              1
--- CH_CFG_USE_SEMAPHORES_PRIORITY:     0
--- CH_CFG_USE_MUTEXES:                 1
--- CH_CFG_USE_MUTEXES_RECURSIVE:       0
--- CH_CFG_USE_CONDVARS:                1
--- CH_CFG_USE_CONDVARS_TIMEOUT:        1
--- CH_CFG_USE_EVENTS:                  1
--- CH_CFG_USE_EVENTS_TIMEOUT:          1
--- CH_CFG_USE_MESSAGES:                1
--- CH_CFG_USE_MESSAGES_PRIORITY:       0
--- CH_CFG_USE_DYNAMIC:                 1
--- CH_DBG_STATISTICS:                  0
--- CH_DBG_SYSTEM_STATE_CHECK:          0
--- CH_DBG_ENABLE_CHECKS:               0
--- CH_DBG_ENABLE_ASSERTS:              0
--- CH_DBG_TRACE_MASK:                  255
--- CH_DBG_TRACE_BUFFER_SIZE:           128
--- CH_DBG_ENABLE_STACK_CHECK:          0
--- CH_DBG_FILL_THREADS:                0
--- CH_DBG_THREADS_PROFILING:           0
--- Result: SUCCESS
=== Test Sequence 2 (System layer and port interface)
--- Test Case 2.1 (System integrity functionality)
--- Result: SUCCESS
--- Test Case 2.2 (Critical zones functionality)
--- Result: SUCCESS
--- Test Case 2.3 (Interrupts handling functionality)
--- Result: SUCCESS
=== Test Sequence 3 (Time and Intervals Functionality)
--- Test Case 3.1 (System Tick Counter functionality)
--- Result: SUCCESS
--- Test Case 3.2 (Time ranges functionality)
--- Result: SUCCESS
=== Test Sequence 4 (Time Stamps Functionality)
--- Test Case 4.1 (Time Stamps functionality)
--- Result: SUCCESS
=== Test Sequence 5 (Threads Functionality)
--- Test Case 5.1 (Thread Sleep functionality)
--- Result: SUCCESS
--- Test Case 5.2 (Ready List functionality, threads priority order)
--- Result: SUCCESS
--- Test Case 5.3 (Priority change test)
--- Result: SUCCESS
--- Test Case 5.4 (Priority change test with Priority Inheritance)
--- Result: SUCCESS
=== Test Sequence 6 (Suspend/Resume)
--- Test Case 6.1 (Suspend and Resume functionality)
--- Result: SUCCESS
=== Test Sequence 7 (Counter Semaphores)
--- Test Case 7.1 (Semaphore primitives, no state change)
--- Result: SUCCESS
--- Test Case 7.2 (Semaphore enqueuing test)
--- Result: SUCCESS
--- Test Case 7.3 (Semaphore timeout test)
--- Result: SUCCESS
--- Test Case 7.4 (Testing chSemAddCounterI() functionality)
--- Result: SUCCESS
--- Test Case 7.5 (Testing chSemWaitSignal() functionality)
--- Result: SUCCESS
--- Test Case 7.6 (Testing Binary Semaphores special case)
--- Result: SUCCESS
=== Test Sequence 8 (Mutexes, Condition Variables and Priority Inheritance)
--- Test Case 8.1 (Priority enqueuing test)
--- Result: SUCCESS
--- Test Case 8.2 (Priority return verification)
--- Result: SUCCESS
--- Test Case 8.3 (Repeated locks, non recursive scenario)
--- Result: SUCCESS
--- Test Case 8.4 (Condition Variable signal test)
--- Result: SUCCESS
--- Test Case 8.5 (Condition Variable broadcast test)
--- Result: SUCCESS
--- Test Case 8.6 (Condition Variable priority boost test)
--- Result: SUCCESS
=== Test Sequence 9 (Synchronous Messages)
--- Test Case 9.1 (Messages Server loop)
--- Result: SUCCESS
=== Test Sequence 10 (Event Sources and Event Flags)
--- Test Case 10.1 (Events registration)
--- Result: SUCCESS
--- Test Case 10.2 (Event Flags dispatching)
--- Result: SUCCESS
--- Test Case 10.3 (Events Flags wait using chEvtWaitOne())
--- Result: SUCCESS
--- Test Case 10.4 (Events Flags wait using chEvtWaitAny())
--- Result: SUCCESS
--- Test Case 10.5 (Events Flags wait using chEvtWaitAll())
--- Result: SUCCESS
--- Test Case 10.6 (Events Flags wait timeouts)
--- Result: SUCCESS
--- Test Case 10.7 (Broadcasting using chEvtBroadcast())
--- Result: SUCCESS
=== Test Sequence 11 (Dynamic threads)
--- Test Case 11.1 (Threads creation from Memory Heap)
--- Result: SUCCESS
--- Test Case 11.2 (Threads creation from Memory Pool)
--- Result: SUCCESS
=== Test Sequence 12 (Benchmarks)
--- Test Case 12.1 (Messages performance #1)
--- Score : 3333324 msgs/S, 6666648 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.2 (Messages performance #2)
--- Score : 2954538 msgs/S, 5909076 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.3 (Messages performance #3)
--- Result: SUCCESS
--- Test Case 12.4 (Context Switch performance)
--- Score : 10297008 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.5 (Threads performance, full cycle)
--- Score : 1857138 threads/S
--- Result: SUCCESS
--- Test Case 12.6 (Threads performance, create/exit only)
--- Score : 2203385 threads/S
--- Result: SUCCESS
--- Test Case 12.7 (Mass reschedule performance)
--- Score : 884352 reschedules/S, 5306112 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.8 (Round-Robin voluntary reschedule)
--- Score : 5832848 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.9 (Virtual Timers set/reset performance)
--- Score : 3434490 timers/S
--- Result: SUCCESS
--- Test Case 12.10 (Semaphores wait/signal performance)
--- Score : 16774148 wait+signal/S
--- Result: SUCCESS
--- Test Case 12.11 (Mutexes lock/unlock performance)
--- Score : 8124980 lock+unlock/S
--- Result: SUCCESS
--- Test Case 12.12 (RAM Footprint)
--- OS    : 136 bytes
--- Thread: 72 bytes
--- Timer : 24 bytes
--- Semaph: 12 bytes
--- Mutex : 16 bytes
--- CondV.: 8 bytes
--- EventS: 4 bytes
--- EventL: 20 bytes
--- MailB.: 40 bytes
--- Result: SUCCESS
Final result: SUCCESS
*** ChibiOS OS Library Test Suite
--- Result: SUCCESS
--- Test Case 1.2 (OS Library Info)
--- Product:                            ChibiOS/LIB
--- Stable Flag:                        0
--- Version String:                     1.4.0
--- Major Number:                       1
--- Minor Number:                       4
--- Patch Number:                       0
--- Result: SUCCESS
--- Test Case 1.3 (OS Library Settings)
--- CH_CFG_USE_MAILBOXES:               1
--- CH_CFG_USE_MEMCORE:                 1
--- CH_CFG_USE_HEAP:                    1
--- CH_CFG_USE_MEMPOOLS:                1
--- CH_CFG_USE_OBJ_FIFOS:               1
--- CH_CFG_USE_PIPES:                   1
--- CH_CFG_USE_OBJ_CACHES:              1
--- CH_CFG_USE_DELEGATES:               1
--- CH_CFG_USE_FACTORY:                 1
--- CH_CFG_FACTORY_MAX_NAMES_LENGTH:    8
--- CH_CFG_FACTORY_OBJECTS_REGISTRY:    1
--- CH_CFG_FACTORY_GENERIC_BUFFERS:     1
--- CH_CFG_FACTORY_SEMAPHORES:          1
--- CH_CFG_FACTORY_MAILBOXES:           1
--- CH_CFG_FACTORY_OBJ_FIFOS:           1
--- CH_CFG_FACTORY_PIPES:               1
--- Result: SUCCESS
=== Test Sequence 2 (Mailboxes)
--- Test Case 2.1 (Mailbox normal API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 2.2 (Mailbox I-Class API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 2.3 (Mailbox timeouts)
--- Result: SUCCESS
=== Test Sequence 3 (Pipes)
--- Test Case 3.1 (Pipes normal API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 3.2 (Pipe timeouts)
--- Result: SUCCESS
=== Test Sequence 4 (Jobs Queues)
--- Test Case 4.1 (Dispatcher test)
--- Result: SUCCESS
=== Test Sequence 5 (Thread Delegates)
--- Test Case 5.1 (Dispatcher test)
--- Result: SUCCESS
=== Test Sequence 6 (Objects Caches)
--- Test Case 6.1 (Cache initialization)
--- Result: SUCCESS
=== Test Sequence 7 (Memory Pools)
--- Test Case 7.1 (Loading and emptying a memory pool)
--- Result: SUCCESS
--- Test Case 7.2 (Loading and emptying a guarded memory pool without waiting)
--- Result: SUCCESS
--- Test Case 7.3 (Guarded Memory Pools timeout)
--- Result: SUCCESS
=== Test Sequence 8 (Memory Heaps)
--- Test Case 8.1 (Allocation and fragmentation)
--- Result: SUCCESS
--- Test Case 8.2 (Default Heap)
--- Result: SUCCESS
=== Test Sequence 9 (Objects Factory)
--- Test Case 9.1 (Objects Registry)
--- Result: SUCCESS
--- Test Case 9.2 (Dynamic Buffers Factory)
--- Result: SUCCESS
--- Test Case 9.3 (Dynamic Semaphores Factory)
--- Result: SUCCESS
--- Test Case 9.4 (Dynamic Mailboxes Factory)
--- Result: SUCCESS
--- Test Case 9.5 (Dynamic Objects FIFOs Factory)
--- Result: SUCCESS
--- Test Case 9.6 (Dynamic Pipes Factory)
--- Result: SUCCESS
11.2.1
*** Compiled:     Apr 24 2022 - 14:31:47
*** Text size:    50768 bytes
*** RO data size: 10464 bytes
--- Compiler:                           GCC 11.2.1 20220111
--- Result: SUCCESS
--- Stable Flag:                        0
--- Major Number:                       7
--- Minor Number:                       1
--- Patch Number:                       0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 1884053 threads/S
--- Result: SUCCESS
--- Score : 2241374 threads/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 5836120 ctxswc/S
--- Result: SUCCESS
--- Score : 3434610 timers/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- OS    : 136 bytes
--- CondV.: 8 bytes
--- EventS: 4 bytes
--- Result: SUCCESS
--- Result: SUCCESS
--- Stable Flag:                        0
--- Major Number:                       1
--- Minor Number:                       4
--- Patch Number:                       0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
Note that the Linux version has a dependencies problem on Ubuntu/Mint and probably others, GDB does not work, I just took arm-none-eabi-gdb from 10.3.1 and replaced the existing one, it worked....
alex31
Has thanked: 47 times
Been thanked: 81 times
Re: [INFO] ARM GCC 11.2
Postby alex31 » Thu May 12, 2022 10:27 am
For the bleeding edger I have compiled brand new arm-none-eabi-gcc 12.1, with newlib 4.2 and gdb 12.1 (patched)
It should work on ubuntu (or ubuntu derived) 20.04 or later.
On some benchmark, I have seen 5% gain in speed compiled with -Ofast compare to gcc11 (probably due to LTO optimisation), also gdb launch faster and is more responsive.
The static analyzer (-fanalyzer) has improved, and now compiles ChibiOS without false positives, and, good news, without complaining at all :-)
I use this analyzer on my project, but also as a virtual C++ mentor for teaching.
For the C++ nerds, gcc12.1 implements nearly completely C++20, and a subset of C++23.
download link
Alexandre
alex31
Postby alex31 » Thu May 19, 2022 8:45 am
I have uploaded a new version where gdb don't need libiconv as a shared library, it's statically linked instead to avoid dependency.
The link in the original post should bring to the new version.
A.
alex31
Postby alex31 » Thu May 02, 2024 9:59 am
For the early testers, here is an ubuntu 22.04 and derivative version of just released gcc 14 RC1 :
https://drive.google.com/file/d/1-pgIM8 ... sp=sharing
Will update the link and post when 14.1 final will be released (scheduled for mid may)
gdb use the ubuntu installed python3 packages, which make installation of modules (example : use of the svd file to decode peripheral registers fields in the debugger) easier.
use last stable version of usual dependencies (gdb, newlib, etc), keith packard's picolib is also included.
A.
alex31
Postby alex31 » Mon May 13, 2024 7:24 am
gcc 14.1 release (for ubuntu 22.04 or debian) : tarball download link
A.
