That hightec compiler included a library and they worked on the linker on their side, it is not GPL so they can keep their optimizations/fixes private.
I never used LLVM as-is, feel free to propose patches.
Clang/LLVM
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: Clang/LLVM
Based on stable_20.3.x branch, here you go. Works with standard llvm/clang distribution, and ARM gcc compiler (used for linker and built-ins). For some reason LTO doesn't work, so disable that (may want to do that in rules.mk). Having trouble attaching files ..
I started with the GCC rules.mk, since that has been updated most recently. I used the same line ending style that was originally in the LLVM rules.mk (which are mixed) to keep the diff size down. Before comitting, I would harmonize the line endings ...
diff --git c/os/common/startup/ARMCMx/compilers/LLVM/mk/clang.mk w/os/common/startup/ARMCMx/compilers/LLVM/mk/clang.mk
index db0f1e4a8..812f277d2 100644
--- c/os/common/startup/ARMCMx/compilers/LLVM/mk/clang.mk
+++ w/os/common/startup/ARMCMx/compilers/LLVM/mk/clang.mk
@@ -1,19 +1,20 @@
-# Compiler settings
-TRGT = aarch32-
-CC = clang
-CPPC = clang++
-LD = clang
-CP = $(TRGT)objcopy
-AS = $(TRGT)as -x assembler-with-cpp
-AR = $(TRGT)ar
-OD = $(TRGT)objdump
-SZ = $(TRGT)size
-HEX = $(CP) -O ihex
-BIN = $(CP) -O binary
+# Compiler settings
+TRGT = llvm-
+CC = clang
+GCC_CC = arm-none-eabi-gcc
+CPPC = clang++
+LD = $(GCC_CC)
+CP = $(TRGT)objcopy
+AS = $(TRGT)as -x assembler-with-cpp
+AR = $(TRGT)ar
+OD = $(TRGT)objdump
+SZ = $(TRGT)size
+HEX = $(CP) -O ihex
+BIN = $(CP) -O binary
diff --git c/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk w/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk
index 0d6af76e4..b448f8d07 100644
--- c/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk
+++ w/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk
@@ -98,14 +98,13 @@ LSTDIR := $(BUILDDIR)/lst
# Object files groups
TCOBJS := $(addprefix $(OBJDIR)/, $(notdir $(TCSRC:.c=.o)))
-TCPPOBJS := $(addprefix $(OBJDIR)/, $(notdir $(TCPPSRC:.cpp=.o)))
+#TCPPOBJS := $(addprefix $(OBJDIR)/, $(notdir $(TCPPSRC:.cpp=.o)))
+TCPPOBJS := $(addprefix $(OBJDIR)/, $(notdir $(patsubst %.cpp, %.o, $(filter %.cpp, $(TCPPSRC)))))
+TCCOBJS := $(addprefix $(OBJDIR)/, $(notdir $(patsubst %.cc, %.o, $(filter %.cc, $(TCPPSRC)))))
ASMOBJS := $(addprefix $(OBJDIR)/, $(notdir $(ASMSRC:.s=.o)))
ASMXOBJS := $(addprefix $(OBJDIR)/, $(notdir $(ASMXSRC:.S=.o)))
-OBJS := $(ASMXOBJS) $(ASMOBJS) $(ACOBJS) $(TCOBJS) $(ACPPOBJS) $(TCPPOBJS)
-# Paths
-IINCDIR := $(patsubst %,-I%,$(INCDIR) $(DINCDIR) $(UINCDIR))
-LLIBDIR := $(patsubst %,-L%,$(DLIBDIR) $(ULIBDIR))
+#OBJS := $(ASMXOBJS) $(ASMOBJS) $(ACOBJS) $(TCOBJS) $(ACPPOBJS) $(TCPPOBJS)
+OBJS := $(ASMXOBJS) $(ASMOBJS) $(ACOBJS) $(TCOBJS) $(ACPPOBJS) $(TCPPOBJS) $(TCCOBJS)
# Macros
DEFS := $(DDEFS) $(UDEFS)
@@ -121,11 +120,18 @@ ASFLAGS = $(MCFLAGS) $(OPT) $(ADEFS)
ASXFLAGS = $(MCFLAGS) $(OPT) $(ADEFS)
CFLAGS = $(MCFLAGS) $(OPT) $(COPT) $(CWARN) $(DEFS)
CPPFLAGS = $(MCFLAGS) $(OPT) $(CPPOPT) $(CPPWARN) $(DEFS)
-#ASFLAGS = $(MCFLAGS) $(OPT) -Wa,-amhls=$(LSTDIR)/$(notdir $(<:.s=.lst)) $(ADEFS)
-#ASXFLAGS = $(MCFLAGS) $(OPT) -Wa,-amhls=$(LSTDIR)/$(notdir $(<:.S=.lst)) $(ADEFS)
-#CFLAGS = $(MCFLAGS) $(OPT) $(COPT) $(CWARN) -Wa,-alms=$(LSTDIR)/$(notdir $(<:.c=.lst)) $(DEFS)
-#CPPFLAGS = $(MCFLAGS) $(OPT) $(CPPOPT) $(CPPWARN) -Wa,-alms=$(LSTDIR)/$(notdir $(<:.cpp=.lst)) $(DEFS)
-LDFLAGS = $(MCFLAGS) $(OPT) -nostartfiles $(LLIBDIR) -Wl,-Map=$(BUILDDIR)/$(PROJECT).map,--cref,--no-warn-mismatch,--library-path=$(STARTUPLD),--script=$(LDSCRIPT)$(LDOPT)
+ARM_CORTEXM_SYSROOT := \
+ $(shell $(GCC_CC) $(CFLAGS) -print-sysroot 2>&1)
+ARM_CORTEXM_MULTI_DIR := \
+ $(shell $(GCC_CC) $(CFLAGS) -print-multi-directory 2>&1)
+ARM_CORTEXM_BUILTINS := \
+ $(shell $(GCC_CC) $(CFLAGS) -print-libgcc-file-name 2>&1)
+ASFLAGS += --target=arm-none-eabi --sysroot=$(ARM_CORTEXM_SYSROOT)
+ASXFLAGS += --target=arm-none-eabi --sysroot=$(ARM_CORTEXM_SYSROOT)
+CFLAGS += --target=arm-none-eabi --sysroot=$(ARM_CORTEXM_SYSROOT)
+CPPFLAGS += --target=arm-none-eabi --sysroot=$(ARM_CORTEXM_SYSROOT)
# Generate dependency information
ASFLAGS += -MD -MP -MF $(DEPDIR)/$(@F).d
@@ -133,6 +139,11 @@ ASXFLAGS += -MD -MP -MF $(DEPDIR)/$(@F).d
CFLAGS += -MD -MP -MF $(DEPDIR)/$(@F).d
CPPFLAGS += -MD -MP -MF $(DEPDIR)/$(@F).d
+# Paths
+IINCDIR := $(patsubst %,-I%,$(INCDIR) $(DINCDIR) $(UINCDIR))
+LLIBDIR := $(patsubst %,-L%,$(DLIBDIR) $(ULIBDIR) $(ARM_CORTEXM_SYSROOT)/lib/$(ARM_CORTEXM_MULTI_DIR))
+LDFLAGS = $(MCFLAGS) $(OPT) -nostartfiles $(LLIBDIR) $(ARM_CORTEXM_BUILTINS) -Wl,-Map=$(BUILDDIR)/$(PROJECT).map,--cref,--no-warn-mismatch,--library-path=$(STARTUPLD),--script=$(LDSCRIPT)$(LDOPT)
# Paths where to search for sources
VPATH = $(SRCPATHS)
@@ -174,6 +185,15 @@ else
@$(CPPC) -c $(CPPFLAGS) -I. $(IINCDIR) $< -o $@
endif
+$(TCCOBJS) : $(OBJDIR)/%.o : %.cc $(MAKEFILE_LIST)
+ifeq ($(USE_VERBOSE_COMPILE),yes)
+ @echo
+ $(CPPC) -c $(CPPFLAGS) -I. $(IINCDIR) $< -o $@
+else
+ @echo Compiling $(<F)
+ @$(CPPC) -c $(CPPFLAGS) -I. $(IINCDIR) $< -o $@
+endif
$(TCOBJS) : $(OBJDIR)/%.o : %.c $(MAKEFILE_LIST)
@echo
- Contact:
Re: Clang/LLVM
Have to add another variable to pass arguments to the compiler driver for the linker. I called it LDOPT_DRIVER.
This is especially necessary if you use the --specs option, which many of us may use. For example, I use --specs=nano.specs all the time . The --specs option is for the compiler driver, which uses it to generate option flags and arguments for the linker it ends up invoking. When compiling with GCC I would put the --specs in OPT, when using LLVM (which uses the clang compiler, and gcc and ld for linking) I would put --specs in LDOPT_DRIVER.
diff --git a/ChibiOS_20.x.x/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk b/ChibiOS_20.x.x/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk
index bcbdcd9ac..0ce140672 100644
--- a/ChibiOS_20.x.x/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk
+++ b/ChibiOS_20.x.x/os/common/startup/ARMCMx/compilers/LLVM/mk/rules.mk
@@ -5,6 +5,7 @@
# Compiler options
+LDOPT_DRIVER := $(USE_LDOPT_DRIVER)
OPT := $(USE_OPT)
COPT := $(USE_COPT)
CPPOPT := $(USE_CPPOPT)
@@ -142,7 +143,7 @@ CPPFLAGS += -MD -MP -MF $(DEPDIR)/$(@F).d
# Paths
-LDFLAGS = $(MCFLAGS) $(OPT) -nostartfiles $(LLIBDIR) $(ARM_CORTEXM_BUILTINS) -Wl,-Map=$(BUILDDIR)/$(PROJECT).map,--cref,--no-warn-mismatch,--library-path=$(STARTUPLD),--script=$(LDSCRIPT)$(LDOPT)
+LDFLAGS = $(MCFLAGS) $(OPT) $(LDOPT_DRIVER) -nostartfiles $(LLIBDIR) $(ARM_CORTEXM_BUILTINS) -Wl,-Map=$(BUILDDIR)/$(PROJECT).map,--cref,--no-warn-mismatch,--library-path=$(STARTUPLD),--script=$(LDSCRIPT)$(LDOPT)
VPATH = $(SRCPATHS)
Users browsing this forum: No registered users and 54 guests
