[NOTE] Things nice to have
steved
Has thanked: 12 times
Been thanked: 135 times
Re: [NOTE] Things nice to have
Postby steved » Wed Aug 16, 2017 1:46 pm
Thargon wrote:I know, but that is still quite cumbersome imo. I would hope that there is a better way than using explicit compiler directives, like
Simplification is only a few #defines away; for example I have:
#define CACHE_ALIGN         __attribute__((aligned (32))) __attribute__((section(".ram0")))
#define CACHE_ALIGN_ZERO    __attribute__((aligned (32))) __attribute__((section(".bss")))
#define CACHE_NONE          __attribute__((section(".ram3")))
The section names need to lead to definitions in the scatter file.
You then use them in much the way you envisaged:
CACHE_NONE uint8_t shortMessageBuffers[SHORT_MESSAGE_COUNT][SHORT_MESSAGE_MAX_LEN + 2] = { { 0 } };
I'd certainly like to see some standard Chibi memory-related definitions; possibly by type of memory rather than anything else (e.g. cached/non-cached, EEPROM, fast/slow etc)
faisal
Has thanked: 44 times
Been thanked: 60 times
Postby faisal » Thu Apr 11, 2019 4:01 pm
Now that the latest kernels and HAL are released, I suggest starting a new thread with ideas for the next significant releases.
Has thanked: 1076 times
Been thanked: 922 times
Postby Giovanni » Thu Apr 11, 2019 5:37 pm
We can continue here, there are still things in this thread that I need to consider.
About my personal ideas, things I want to do:
- New multi-core kernel or multi core mode in RT.
- Security kernel running in trust zone for new Cortex-M33, threads could be both in secure and non-secure spaces. This implies kernel separation from the application and a true API protocol for entry.
- C++ HAL prototype, not meant to replace current one.
- Add new features to OSLIB, even higher level.
In general, more new things.
JSStabl
Has thanked: 3 times
Been thanked: 2 times
Postby JSStabl » Fri May 15, 2020 12:08 pm
Not sure if this is the right place, but it would be nice to be able to easily switch between a DMA and a non-DMA implementation for the periphery in the HAL. Sometimes all DMA Channels are used for certain pins and one has to manually write non-DMA drivers.
Thargon
Has thanked: 15 times
Been thanked: 24 times
Postby Thargon » Fri May 15, 2020 12:53 pm
I submitted a patch some time ago for the STM32 I2Cv1 LLD: viewtopic.php?f=38&t=4339
A more recent version compatible with ChibiOS 19.1 can be found in my project: https://opensource.cit-ec.de/projects/a ... rev=master
- Thomas
JSStabl
Postby JSStabl » Fri May 15, 2020 1:20 pm
Yeah, incorporating that into all HAL drivers would help a lot :)
Users browsing this forum: No registered users and 12 guests
