Ok, thank you.
There is a new version with a value of 1.
[NEWS] Introducing MFS
Re: [NEWS] Introducing MFS
- Add-EFL-driver-for-F3_v2.zip
- (14.59 KiB) Downloaded 229 times
I've tried EFL-MFS tests on F407 Discovery. (Chibistudio 2021-07-RC1 trunk, GCC 10)
It successfully completes with bank_size 4096 or less, but stops @ Test Case 1.7 (Testing garbage collection by erasing) if I set the bank_size to 8192 or more.
On L476 bigger bank size works just fine.
.bank_size = 8192U,
.bank0_start = 10U, // 128K
.bank0_sectors = 1U,
.bank1_start = 11U, // 128K
.bank1_sectors = 1U
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Exactly which step is failing in TC 17?
It could be a limit of the test case, could you try to increase MFS_CFG_MAX_RECORDS proportionally? it is 32, try making it 128.
Currently I have no way to run the test.
- Contact:
rreignier wrote:Ok, thank you.
Totally forgot about this....
- Contact:
Users browsing this forum: No registered users and 35 guests
