Lets open the development thread also for the new G4. It looks like a replacement for the ageing F3, interesting device, much higher performance.
[DEV] STM32G4xx support
Re: [DEV] STM32G4xx support
Perhaps they wanted to keep it as close as possible to the F3, the ADC should be able to do 16 bits by doing oversampling like the one on L4/L4+.
Giovanni.
Giovanni.
Any updates on G4 support?
It looks really promising for FOC motor control related tasks.
I want to port VESC ESC BLDC controller on G4, it is much more suitable than old F4.
ST itself released small FOC ESC discovery board:
https://www.st.com/content/ccc/resource ... 564746.pdf
I agree, it is very interesting.
I am waiting for boards, in early September is my guess. Initial support should not take long.
I have the boards, I am looking at the documentation right now, I will start committing some code soon.
Support in OpenOCD would make things easier.
- FXCoder
- Has thanked: 180 times
- Been thanked: 130 times
The last opened windows/Linux set I built for G0 support used a cherry-picked dedicated G0 variant patch that didn't include G4 support.
There is another patch in gerrit which has been in progress for quite some months which modifies the L4 driver to include both G0 and G4.
It isn't through review yet and needs a little more work by the author.
Once that happens I'll cherry-pick that patch and build the Windows and Linux 32/64 openocd set.
I guess that is some weeks off though.
Bob
Bob
From what I see G4 should be similar to L4+. I started committing G4 code so expect progress, it has some things in common with G0 so work will benefit both ports.
Both G0 and G4 are beautiful, they managed to improve the platforms while keeping that "family feeling".
Update.
It is progressing well, code is flowing already in the repository.
Just a note, since G4 is the start of a "new generation" I am taking time and do improvements to the general STM32 HAL organization. The problem is the duplication of code caused by ISR sharing in the stm32_isr.c files, each time it takes time and it is source of copy/paste errors.
I am trying to create some kind of mini-drivers for each TIM unit named for example: stm32_tim2.inc. The various stm32_isr.c files will just include the required .inc files making things faster and less error prone.
Ideally I wish to converge toward this organization:
- ISRs and priority-related error checks are no more in each driver but in those .inc files.
- IRQ priorities are in a dedicated section of the mcuconf.h file and not sparse for each unit type.
- Timers with shared IRQs will be fully supported on all platforms (I was holding back on this because the organization problem).
Example:
Example:
ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
* @file TIMv1/stm32_tim1_tim15_tim16_tim17.inc
* @brief Shared TIM1, TIM15, TIM16, TIM17 handler.
* @addtogroup STM32_TIM1_TIM15_TIM16_TIM17_HANDLER
/* Driver local definitions. */
* @brief IRQ vectors initialization.
#define STM32_TIM1_TIM15_TIM16_TIM17_INIT() do { \
nvicEnableVector(STM32_TIM1_BRK_TIM15_NUMBER, \
STM32_IRQ_TIM1_BRK_TIM15_PRIORITY); \
nvicEnableVector(STM32_TIM1_UP_TIM16_NUMBER, \
STM32_IRQ_TIM1_UP_TIM16_PRIORITY); \
nvicEnableVector(STM32_TIM1_TRGCO_TIM17_NUMBER, \
STM32_IRQ_TIM1_TRGCO_TIM17_PRIORITY); \
nvicEnableVector(STM32_TIM1_CC_NUMBER, \
STM32_IRQ_TIM1_CC_PRIORITY); \
} while (0)
* @brief IRQ vectors de-initialization.
#define STM32_TIM1_TIM15_TIM16_TIM17_DEINIT() do { \
nvicDisableVector(STM32_TIM1_BRK_TIM15_NUMBER); \
nvicDisableVector(STM32_TIM1_UP_TIM16_NUMBER); \
nvicDisableVector(STM32_TIM1_TRGCO_TIM17_NUMBER); \
nvicDisableVector(STM32_TIM1_CC_NUMBER); \
} while (0)
/* Derived constants and error checks. */
#if !defined(STM32_IRQ_TIM1_BRK_TIM15_PRIORITY)
#error "STM32_IRQ_TIM1_BRK_TIM15_PRIORITY not defined in mcuconf.h"
#if !defined(STM32_IRQ_TIM1_UP_TIM16_PRIORITY)
#error "STM32_IRQ_TIM1_UP_TIM16_PRIORITY not defined in mcuconf.h"
#if !defined(STM32_IRQ_TIM1_TRGCO_TIM17_PRIORITY)
#error "STM32_IRQ_TIM1_TRGCO_TIM17_PRIORITY not defined in mcuconf.h"
#if !defined(STM32_IRQ_TIM1_CC_PRIORITY)
#error "STM32_IRQ_TIM1_CC_PRIORITY not defined in mcuconf.h"
#if !OSAL_IRQ_IS_VALID_PRIORITY(STM32_IRQ_TIM1_BRK_TIM15_PRIORITY)
#error "Invalid IRQ priority assigned to STM32_IRQ_TIM1_BRK_TIM15_PRIORITY"
#if !OSAL_IRQ_IS_VALID_PRIORITY(STM32_IRQ_TIM1_UP_TIM16_PRIORITY)
#error "Invalid IRQ priority assigned to STM32_IRQ_TIM1_UP_TIM16_PRIORITY"
#if !OSAL_IRQ_IS_VALID_PRIORITY(STM32_IRQ_TIM1_TRGCO_TIM17_PRIORITY)
#error "Invalid IRQ priority assigned to STM32_IRQ_TIM1_TRGCO_TIM17_PRIORITY"
#if !OSAL_IRQ_IS_VALID_PRIORITY(STM32_IRQ_TIM1_CC_PRIORITY)
#error "Invalid IRQ priority assigned to STM32_IRQ_TIM1_CC_PRIORITY"
/* Driver exported variables. */
/* Driver local variables. */
/* Driver local functions. */
/* Driver interrupt handlers. */
#if HAL_USE_GPT || HAL_USE_ICU || HAL_USE_PWM || defined(__DOXYGEN__)
* @brief TIM1-BRK, TIM15 interrupt handler.
* @isr
OSAL_IRQ_HANDLER(STM32_TIM1_BRK_TIM15_NUMBER) {
OSAL_IRQ_PROLOGUE();
#if HAL_USE_GPT
#if STM32_GPT_USE_TIM15
gpt_lld_serve_interrupt(&GPTD15);
#if HAL_USE_ICU
#if STM32_ICU_USE_TIM15
icu_lld_serve_interrupt(&ICUD15);
#if HAL_USE_PWM
#if STM32_PWM_USE_TIM15
pwm_lld_serve_interrupt(&PWMD15);
OSAL_IRQ_EPILOGUE();
* @brief TIM1-UP, TIM16 interrupt handler.
* @isr
OSAL_IRQ_HANDLER(STM32_TIM1_UP_TIM16_NUMBER) {
#if HAL_USE_GPT
gpt_lld_serve_interrupt(&GPTD1);
#if STM32_GPT_USE_TIM16
gpt_lld_serve_interrupt(&GPTD16);
#if HAL_USE_ICU
icu_lld_serve_interrupt(&ICUD1);
#if HAL_USE_PWM
pwm_lld_serve_interrupt(&PWMD1);
#if STM32_PWM_USE_TIM16
pwm_lld_serve_interrupt(&PWMD16);
* @brief TIM1-TRG-COM, TIM17 interrupt handler.
* @isr
OSAL_IRQ_HANDLER(STM32_TIM1_TRGCO_TIM17_NUMBER) {
#if HAL_USE_GPT
#if STM32_GPT_USE_TIM17
gpt_lld_serve_interrupt(&GPTD17);
#if HAL_USE_ICU
/* Not used by ICU.*/
#if HAL_USE_PWM
#if STM32_PWM_USE_TIM17
pwm_lld_serve_interrupt(&PWMD17);
* @brief TIM1-CC interrupt handler.
* @isr
OSAL_IRQ_HANDLER(STM32_TIM1_CC_NUMBER) {
#if HAL_USE_GPT
/* Not used by GPT.*/
#if HAL_USE_ICU
#if HAL_USE_PWM
#endif /* HAL_USE_GPT || HAL_USE_ICU || HAL_USE_PWM */
/* Driver exported functions. */
Users browsing this forum: No registered users and 19 guests
