HI all,
i needed efl support for STM32F072 so i ported STM32F1 efl code to F0. I have no other F0 Hardware here so only tested on F072.
Regards
Tec
F0 EFL Patch
- Has thanked: 21 times
- Been thanked: 5 times
Re: F0 EFL Patch
Is it needed to take the sectors used in EFL MFS out of the linker script? So my device is 32 sectors and i use sector 30 and 31. From a first look it makes no difference if i use the stock .ld file or a modified one where the last 2 sectors are not in flash like below?
* STM32F072xB memory setup.
MEMORY
flash0 (rx) : org = 0x08000000, len = 120k
flash1 (rx) : org = 0x00000000, len = 0
flash2 (rx) : org = 0x00000000, len = 0
flash3 (rx) : org = 0x00000000, len = 0
flash4 (rx) : org = 0x00000000, len = 0
flash5 (rx) : org = 0x00000000, len = 0
flash6 (rx) : org = 0x00000000, len = 0
flash7 (rx) : org = 0x00000000, len = 0
ram0 (wx) : org = 0x20000000, len = 16k
ram1 (wx) : org = 0x00000000, len = 0
ram2 (wx) : org = 0x00000000, len = 0
ram3 (wx) : org = 0x00000000, len = 0
ram4 (wx) : org = 0x00000000, len = 0
ram5 (wx) : org = 0x00000000, len = 0
ram6 (wx) : org = 0x00000000, len = 0
ram7 (wx) : org = 0x00000000, len = 0
eeprom (rw) : org = 0x0801E000, len = 8k
Re: F0 EFL Patch
Default ld files do not need to be "aware" of the rest of SW. If you use MFS on internal flash it is your responsibility to create ad-hoc ld files.
Different layers in the architectures.
