Capturing events/signals in delegate/worker threads
- Has thanked: 1074 times
- Been thanked: 921 times
Re: Capturing events/signals in delegate/worker threads
You mean while doing chDelegateDispatch() ?
Something like:
You would need something to allocate event ids, and register a callback for each ID. chEvtDispatch() can be used to process the incoming events. Just need an API to populate the eventhandler_t[], and return back an allocated eventid and thread_t - which the client can then go and give to event sources.
/* from client - the eventual handler for the event */
void callback_on_event (void) {
/* This gets called by the delegate/worker thread
* once the event is generated by other_module_generate_event()
void setup_callback_on_event() {
thread_t * thd;
event_id id;
chDelegate_allocate_thread_signal (&thd, &id, callback_on_event);
other_module_use_this_thread_signal(thd, id);
/* in other module which generates the event */
void other_module_use_this_thread_signal(thread_t * thd, eventid_t id) {
stored_thd = thd;
stored_id = id;
void other_module_generate_event (void) {
chEvtSignal(stored_thd, EVENT_MASK(stored_id))
Users browsing this forum: No registered users and 21 guests
