[INFO] ARM GCC 11.2
[INFO] ARM GCC 11.2
Postby Giovanni » Sun Apr 24, 2022 6:46 pm
I tested using the latest GCC from ARM, no revolutionary changes, few benchmarks improved a bit.
10.3.1
*** ChibiOS/RT Test Suite
*** Compiled:     Apr 24 2022 - 19:39:20
*** Platform:     STM32H735 Single Core Very High Performance with DSP and FPU
*** Test Board:   STMicroelectronics STM32H735IG_DISCOVERY
*** Text size:    50712 bytes
*** RO data size: 10476 bytes
*** Data size:    220 bytes
*** BSS size:     5952 bytes
=== Test Sequence 1 (Information)
--- Test Case 1.1 (Port Info)
--- Architecture:                       ARMv7E-M
--- Core Variant:                       Cortex-M7
--- Compiler:                           GCC 10.3.1 20210824 (release)
--- Port Info:                          Advanced kernel mode
--- Natural alignment:                  4
--- Stack alignment:                    8
--- Working area alignment:             8
--- Result: SUCCESS
--- Test Case 1.2 (Kernel Info)
--- Product:                            ChibiOS/RT
--- Stable Flag:                        0
--- Version String:                     7.1.0
--- Major Number:                       7
--- Minor Number:                       1
--- Patch Number:                       0
--- Result: SUCCESS
--- Test Case 1.3 (Kernel Settings)
--- CH_CFG_ST_RESOLUTION:               32
--- CH_CFG_ST_FREQUENCY:                10000
--- CH_CFG_INTERVALS_SIZE:              32
--- CH_CFG_TIME_TYPES_SIZE:             32
--- CH_CFG_ST_TIMEDELTA:                2
--- CH_CFG_TIME_QUANTUM:                0
--- CH_CFG_MEMCORE_SIZE:                0
--- CH_CFG_NO_IDLE_THREAD:              0
--- CH_CFG_OPTIMIZE_SPEED:              1
--- CH_CFG_USE_TM:                      1
--- CH_CFG_USE_REGISTRY:                1
--- CH_CFG_USE_WAITEXIT:                1
--- CH_CFG_USE_SEMAPHORES:              1
--- CH_CFG_USE_SEMAPHORES_PRIORITY:     0
--- CH_CFG_USE_MUTEXES:                 1
--- CH_CFG_USE_MUTEXES_RECURSIVE:       0
--- CH_CFG_USE_CONDVARS:                1
--- CH_CFG_USE_CONDVARS_TIMEOUT:        1
--- CH_CFG_USE_EVENTS:                  1
--- CH_CFG_USE_EVENTS_TIMEOUT:          1
--- CH_CFG_USE_MESSAGES:                1
--- CH_CFG_USE_MESSAGES_PRIORITY:       0
--- CH_CFG_USE_DYNAMIC:                 1
--- CH_DBG_STATISTICS:                  0
--- CH_DBG_SYSTEM_STATE_CHECK:          0
--- CH_DBG_ENABLE_CHECKS:               0
--- CH_DBG_ENABLE_ASSERTS:              0
--- CH_DBG_TRACE_MASK:                  255
--- CH_DBG_TRACE_BUFFER_SIZE:           128
--- CH_DBG_ENABLE_STACK_CHECK:          0
--- CH_DBG_FILL_THREADS:                0
--- CH_DBG_THREADS_PROFILING:           0
--- Result: SUCCESS
=== Test Sequence 2 (System layer and port interface)
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
=== Test Sequence 3 (Time and Intervals Functionality)
--- Test Case 3.1 (System Tick Counter functionality)
--- Result: SUCCESS
--- Test Case 3.2 (Time ranges functionality)
--- Result: SUCCESS
=== Test Sequence 4 (Time Stamps Functionality)
--- Test Case 4.1 (Time Stamps functionality)
--- Result: SUCCESS
=== Test Sequence 5 (Threads Functionality)
--- Test Case 5.1 (Thread Sleep functionality)
--- Result: SUCCESS
--- Test Case 5.2 (Ready List functionality, threads priority order)
--- Result: SUCCESS
--- Test Case 5.3 (Priority change test)
--- Result: SUCCESS
--- Test Case 5.4 (Priority change test with Priority Inheritance)
--- Result: SUCCESS
=== Test Sequence 6 (Suspend/Resume)
--- Test Case 6.1 (Suspend and Resume functionality)
--- Result: SUCCESS
=== Test Sequence 7 (Counter Semaphores)
--- Test Case 7.1 (Semaphore primitives, no state change)
--- Result: SUCCESS
--- Test Case 7.2 (Semaphore enqueuing test)
--- Result: SUCCESS
--- Test Case 7.3 (Semaphore timeout test)
--- Result: SUCCESS
--- Test Case 7.4 (Testing chSemAddCounterI() functionality)
--- Result: SUCCESS
--- Test Case 7.5 (Testing chSemWaitSignal() functionality)
--- Result: SUCCESS
--- Test Case 7.6 (Testing Binary Semaphores special case)
--- Result: SUCCESS
=== Test Sequence 8 (Mutexes, Condition Variables and Priority Inheritance)
--- Test Case 8.1 (Priority enqueuing test)
--- Result: SUCCESS
--- Test Case 8.2 (Priority return verification)
--- Result: SUCCESS
--- Test Case 8.3 (Repeated locks, non recursive scenario)
--- Result: SUCCESS
--- Test Case 8.4 (Condition Variable signal test)
--- Result: SUCCESS
--- Test Case 8.5 (Condition Variable broadcast test)
--- Result: SUCCESS
--- Test Case 8.6 (Condition Variable priority boost test)
--- Result: SUCCESS
=== Test Sequence 9 (Synchronous Messages)
--- Test Case 9.1 (Messages Server loop)
--- Result: SUCCESS
=== Test Sequence 10 (Event Sources and Event Flags)
--- Test Case 10.1 (Events registration)
--- Result: SUCCESS
--- Test Case 10.2 (Event Flags dispatching)
--- Result: SUCCESS
--- Test Case 10.3 (Events Flags wait using chEvtWaitOne())
--- Result: SUCCESS
--- Test Case 10.4 (Events Flags wait using chEvtWaitAny())
--- Result: SUCCESS
--- Test Case 10.5 (Events Flags wait using chEvtWaitAll())
--- Result: SUCCESS
--- Test Case 10.6 (Events Flags wait timeouts)
--- Result: SUCCESS
--- Test Case 10.7 (Broadcasting using chEvtBroadcast())
--- Result: SUCCESS
=== Test Sequence 11 (Dynamic threads)
--- Test Case 11.1 (Threads creation from Memory Heap)
--- Result: SUCCESS
--- Test Case 11.2 (Threads creation from Memory Pool)
--- Result: SUCCESS
=== Test Sequence 12 (Benchmarks)
--- Test Case 12.1 (Messages performance #1)
--- Score : 3333324 msgs/S, 6666648 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.2 (Messages performance #2)
--- Score : 2954538 msgs/S, 5909076 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.3 (Messages performance #3)
--- Result: SUCCESS
--- Test Case 12.4 (Context Switch performance)
--- Score : 10297008 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.5 (Threads performance, full cycle)
--- Score : 1857138 threads/S
--- Result: SUCCESS
--- Test Case 12.6 (Threads performance, create/exit only)
--- Score : 2203385 threads/S
--- Result: SUCCESS
--- Test Case 12.7 (Mass reschedule performance)
--- Score : 884352 reschedules/S, 5306112 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.8 (Round-Robin voluntary reschedule)
--- Score : 5832848 ctxswc/S
--- Result: SUCCESS
--- Test Case 12.9 (Virtual Timers set/reset performance)
--- Score : 3434490 timers/S
--- Result: SUCCESS
--- Test Case 12.10 (Semaphores wait/signal performance)
--- Score : 16774148 wait+signal/S
--- Result: SUCCESS
--- Test Case 12.11 (Mutexes lock/unlock performance)
--- Score : 8124980 lock+unlock/S
--- Result: SUCCESS
--- Test Case 12.12 (RAM Footprint)
--- OS    : 136 bytes
--- Thread: 72 bytes
--- Timer : 24 bytes
--- Semaph: 12 bytes
--- Mutex : 16 bytes
--- CondV.: 8 bytes
--- EventS: 4 bytes
--- EventL: 20 bytes
--- MailB.: 40 bytes
--- Result: SUCCESS
Final result: SUCCESS
*** ChibiOS OS Library Test Suite
--- Result: SUCCESS
--- Test Case 1.2 (OS Library Info)
--- Product:                            ChibiOS/LIB
--- Stable Flag:                        0
--- Version String:                     1.4.0
--- Major Number:                       1
--- Minor Number:                       4
--- Patch Number:                       0
--- Result: SUCCESS
--- Test Case 1.3 (OS Library Settings)
--- CH_CFG_USE_MAILBOXES:               1
--- CH_CFG_USE_MEMCORE:                 1
--- CH_CFG_USE_HEAP:                    1
--- CH_CFG_USE_MEMPOOLS:                1
--- CH_CFG_USE_OBJ_FIFOS:               1
--- CH_CFG_USE_PIPES:                   1
--- CH_CFG_USE_OBJ_CACHES:              1
--- CH_CFG_USE_DELEGATES:               1
--- CH_CFG_USE_FACTORY:                 1
--- CH_CFG_FACTORY_MAX_NAMES_LENGTH:    8
--- CH_CFG_FACTORY_OBJECTS_REGISTRY:    1
--- CH_CFG_FACTORY_GENERIC_BUFFERS:     1
--- CH_CFG_FACTORY_SEMAPHORES:          1
--- CH_CFG_FACTORY_MAILBOXES:           1
--- CH_CFG_FACTORY_OBJ_FIFOS:           1
--- CH_CFG_FACTORY_PIPES:               1
--- Result: SUCCESS
=== Test Sequence 2 (Mailboxes)
--- Test Case 2.1 (Mailbox normal API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 2.2 (Mailbox I-Class API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 2.3 (Mailbox timeouts)
--- Result: SUCCESS
=== Test Sequence 3 (Pipes)
--- Test Case 3.1 (Pipes normal API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 3.2 (Pipe timeouts)
--- Result: SUCCESS
=== Test Sequence 4 (Jobs Queues)
--- Test Case 4.1 (Dispatcher test)
--- Result: SUCCESS
=== Test Sequence 5 (Thread Delegates)
--- Test Case 5.1 (Dispatcher test)
--- Result: SUCCESS
=== Test Sequence 6 (Objects Caches)
--- Test Case 6.1 (Cache initialization)
--- Result: SUCCESS
=== Test Sequence 7 (Memory Pools)
--- Test Case 7.1 (Loading and emptying a memory pool)
--- Result: SUCCESS
--- Test Case 7.2 (Loading and emptying a guarded memory pool without waiting)
--- Result: SUCCESS
--- Test Case 7.3 (Guarded Memory Pools timeout)
--- Result: SUCCESS
=== Test Sequence 8 (Memory Heaps)
--- Test Case 8.1 (Allocation and fragmentation)
--- Result: SUCCESS
--- Test Case 8.2 (Default Heap)
--- Result: SUCCESS
=== Test Sequence 9 (Objects Factory)
--- Test Case 9.1 (Objects Registry)
--- Result: SUCCESS
--- Test Case 9.2 (Dynamic Buffers Factory)
--- Result: SUCCESS
--- Test Case 9.3 (Dynamic Semaphores Factory)
--- Result: SUCCESS
--- Test Case 9.4 (Dynamic Mailboxes Factory)
--- Result: SUCCESS
--- Test Case 9.5 (Dynamic Objects FIFOs Factory)
--- Result: SUCCESS
--- Test Case 9.6 (Dynamic Pipes Factory)
--- Result: SUCCESS
11.2.1
*** Compiled:     Apr 24 2022 - 14:31:47
*** Text size:    50768 bytes
*** RO data size: 10464 bytes
--- Compiler:                           GCC 11.2.1 20220111
--- Result: SUCCESS
--- Stable Flag:                        0
--- Major Number:                       7
--- Minor Number:                       1
--- Patch Number:                       0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 1884053 threads/S
--- Result: SUCCESS
--- Score : 2241374 threads/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 5836120 ctxswc/S
--- Result: SUCCESS
--- Score : 3434610 timers/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- OS    : 136 bytes
--- CondV.: 8 bytes
--- EventS: 4 bytes
--- Result: SUCCESS
--- Result: SUCCESS
--- Stable Flag:                        0
--- Major Number:                       1
--- Minor Number:                       4
--- Patch Number:                       0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
Note that the Linux version has a dependencies problem on Ubuntu/Mint and probably others, GDB does not work, I just took arm-none-eabi-gdb from 10.3.1 and replaced the existing one, it worked....
alex31
Has thanked: 38 times
Been thanked: 62 times
Re: [INFO] ARM GCC 11.2
Postby alex31 » Thu May 12, 2022 10:27 am
For the bleeding edger I have compiled brand new arm-none-eabi-gcc 12.1, with newlib 4.2 and gdb 12.1 (patched)
It should work on ubuntu (or ubuntu derived) 20.04 or later.
On some benchmark, I have seen 5% gain in speed compiled with -Ofast compare to gcc11 (probably due to LTO optimisation), also gdb launch faster and is more responsive.
The static analyzer (-fanalyzer) has improved, and now compiles ChibiOS without false positives, and, good news, without complaining at all :-)
I use this analyzer on my project, but also as a virtual C++ mentor for teaching.
For the C++ nerds, gcc12.1 implements nearly completely C++20, and a subset of C++23.
download link
Alexandre
alex31
Postby alex31 » Thu May 19, 2022 8:45 am
I have uploaded a new version where gdb don't need libiconv as a shared library, it's statically linked instead to avoid dependency.
The link in the original post should bring to the new version.
A.
