EFL internal flash driver on single bank MCU
Posted: Fri Jul 25, 2025 10:39 am
by alex31
I have to write a bootloader able to flash the application (from external SPI eeprom) on a stm32g491 (512Kb, single bank).
from what I have understood, most of the bootloader code can reside in flash, but the part that actually erase and program the flash should run from RAM since one bank devices does not permit 'read while write' and programming the flash will stall the program.
It means some magic incantation in the linker file, a routine that copy the function from flash to ram, blocking IT when the RAM function is running.
Is the EFL driver aware of that and can be used for my use case ?
Alexandre
Re: EFL internal flash driver on single bank MCU
Posted: Fri Jul 25, 2025 11:38 am
Startup files can copy code in RAM but the EFL driver would need an extra information: the linker section name where the code should be copied (could be a configuration).
Posted: Fri Jul 25, 2025 2:38 pm
by alex31
I will give a try, I will decorate the EFL api and lld functions with a macro that can be nothing or an attribute section.
should I also decorate the functions declared inline ? If they are really inlined, there should be no need, but I dont't know if inline is only a hint or an order that the compiler must follow ?
Posted: Fri Jul 25, 2025 2:50 pm
You should use portability macros, no compiler-specific code into the drivers.
Posted: Sat Jul 26, 2025 10:46 am
by alex31
Some information on flash memory I discovered while experimenting with the STM32G4 and ChibiOS:
The EFL module is designed around MFS use cases and relies on a VMT-based API, which is not suitable for direct flash operations. So if you need to use flash for anything other than a filesystem, you’ll have to go through the LLD API.
Using the portability macro to place the flash programming function in RAM works well, but only if you also protect the write loop with chSysLock()/chSysUnlock(). Without that, any interrupt that occurs during programming may try to execute ISR code still in flash, which causes the system to stall until the flash operation completes.
Performance gain: writing a 2KB page went from 24 ms down to 1 ms (24× improvement) when stm32_flash_enable_pgm() is placed in RAM.
This gain isn’t very useful for MFS (which typically writes small chunks), but for a bootloader performing IAP, it’s a big deal.
I’ve also implemented fast programming mode (writing 256 bytes in a row), but it only works after a mass erase. This implies the entire bootloader must run from RAM. That means embedding the full bootloader as data within the main application, copying it to RAM, and jumping to it when needed.
Does anyone have suggestions or best practices for embedding and executing a complete application from RAM (not just a few functions) on STM32?
I have included the patch which is dead simple for the test, if included it will need more work for all the architecture, the documentation of HAL_EFL_SECTION_HOOK macro, etc.
In mcuconf, I added :
#define HAL_EFL_SECTION_HOOK __attribute__((section(".ram4_init"), noinline, long_call))
Alexandre
Posted: Wed Jul 30, 2025 7:04 pm
Why the API is not suitable for direct flash operations? it should be quite generic, it is not meant for MFS only.
Posted: Thu Jul 31, 2025 6:07 pm
by alex31
Is there more that these functions in the generic API ?
/* External declarations.                                                    */
#ifdef __cplusplus
extern "C" {
  void  eflInit(void);
  void  eflObjectInit(EFlashDriver *eflp);
  msg_t eflStart(EFlashDriver *eflp, const EFlashConfig *config);
  void  eflStop(EFlashDriver *eflp);
#ifdef __cplusplus
For my use case, I also need generic API that wrap these lld functions :
 flash_error_t efl_lld_read(void *instance, flash_offset_t offset,
                             size_t n, uint8_t *rp);
  flash_error_t efl_lld_program(void *instance, flash_offset_t offset,
                                size_t n, const uint8_t *pp);
  flash_error_t efl_lld_start_erase_all(void *instance);
  flash_error_t efl_lld_start_erase_sector(void *instance,
                                           flash_sector_t sector);
  flash_error_t efl_lld_query_erase(void *instance, uint32_t *msec);
  flash_error_t efl_lld_verify_erase(void *instance, flash_sector_t sector);
I probably missed something :-)
Alexandre
Posted: Thu Jul 31, 2025 6:37 pm
Yes, the functions are not in that module, you need to look into the flash interface, those functions work on any flash of any kind.
