At the moment all the SD driver buffer sizes are set by the define SERIAL_BUFFERS_SIZE in halconfig.h
This is quite wasteful as your asuming all SD drivers need the same buffer/queue size.
So a small light weight protocol might only need a queue size of 16bytes, but another SD driver outputting large strings may need 256bytes. But as there is only one define we are wasting memory for the light weight protocol.
may be we could have individual settings for each SD driver that are in the mcuconf file i.e
* SERIAL driver system settings.
#define STM32_SERIAL_USE_USART1 TRUE
#define STM32_SERIAL_USE_USART2 TRUE
#define STM32_SERIAL_USE_USART3 FALSE
#define STM32_SERIAL_USART1_PRIORITY 12
#define STM32_SERIAL_USART2_PRIORITY 12
#define STM32_SERIAL_USART3_PRIORITY 12
#define STM32_SERIAL_USART1_BUFSIZE 16
#define STM32_SERIAL_USART2_BUFSIZE 256
#define STM32_SERIAL_USART3_BUFSIZE 16
Serial Device Drivers buffer size Topic is solved
Re: Serial Device Drivers buffer size
The change would be quite extensive, it would affect a lot of existing drivers drivers and also SW not directly under my control, the SPC5 drivers for example.
The idea is good but you should not expect a quick implementation for this.
Maybe there is a way to do this without affecting existing drivers, moving to the bug reports forum.
I implemented a change in the USARTv2 driver (F0, F3, F7, L0, L4). Now it is possible to setup the size of each in/out queue separately. All other drivers should be unaffected.
Settings should be added to mcuconf.h, if settings are not added then the global setting SERIAL_BUFFERS_SIZE in halconf.h is in effect as usual.
Defaults are:
Could you please give it a try?
Defaults are:
* @brief Input buffer size for USART1.
#if !defined(STM32_SERIAL_USART1_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART1_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for USART1.
#if !defined(STM32_SERIAL_USART1_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART1_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for USART2.
#if !defined(STM32_SERIAL_USART2_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART2_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for USART2.
#if !defined(STM32_SERIAL_USART2_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART2_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for USART3.
#if !defined(STM32_SERIAL_USART3_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART3_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for USART3.
#if !defined(STM32_SERIAL_USART3_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART3_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for UART4.
#if !defined(STM32_SERIAL_UART4_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART4_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for UART4.
#if !defined(STM32_SERIAL_UART4_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART4_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for UART5.
#if !defined(STM32_SERIAL_UART5_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART5_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for UART5.
#if !defined(STM32_SERIAL_UART5_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART5_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for USART6.
#if !defined(STM32_SERIAL_USART6_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART6_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for USART6.
#if !defined(STM32_SERIAL_USART6_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_USART6_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for UART7.
#if !defined(STM32_SERIAL_UART7_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART7_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for UART7.
#if !defined(STM32_SERIAL_UART7_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART7_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for UART8.
#if !defined(STM32_SERIAL_UART8_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART8_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for UART8.
#if !defined(STM32_SERIAL_UART8_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_UART8_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Input buffer size for LPUART1.
#if !defined(STM32_SERIAL_LPUART1_IN_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_LPUART1_IN_BUF_SIZE SERIAL_BUFFERS_SIZE
* @brief Output buffer size for LPUART1.
#if !defined(STM32_SERIAL_LPUART1_OUT_BUF_SIZE) || defined(__DOXYGEN__)
#define STM32_SERIAL_LPUART1_OUT_BUF_SIZE SERIAL_BUFFERS_SIZE
Giovanni wrote:Hi,
Defaults are:Code: Select all
Yeah will do, might not be for a week or so if thats ok, got alot on at the moment
