I think there is a bug in ChibiOS lwipthread / demos that causes pbuf /memp corruption.
First, low_level_input() allocates a pbuf from the pool (PBUF_POOL).
Second, the thread loop calls pbuf_free(), although admitedly it does only for packets of unknown type.
Neither pbuf_alloc() nor pbuf_free() can be safely called from other context than the LwIP worker thread unless in lwipopts.h SYS_LIGHTWEIGHT_PROT is set and/or (not sure about this) LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT is also set, and none of these two options is set in lwipopts.h files in demos shipped with ChibiOS.
Either lwipopts.h needs to be modified or pbuf_alloc_callback() / pbuf_free_callback() must be used instead.
Slightly related I filed this bug some time ago:
https://sourceforge.net/p/chibios/bugs/729/
TL;DR lwipthread calls netif_add() which cannot be called from other context than LwIP worker thread. netconn_netif_add() must be used instead or netif_add() called from the callback that can be passed to tcpip_init().
LwIP pbuf/memp corruption Topic is solved
Re: LwIP pbuf/memp corruption
Just reporting that after extensive stress testing LwIP with changes to lwipopts.h I can confirm that my occasional LwIP pbuf assertion triggers are gone. No more pbufs with invalid ref count, no more memp sanity checks panic.
Giovanni wrote:Thanks, I will make changes, do you have a patch ready?
Nope, sorry. Change is trivial, just enable SYS_LIGHTWEIGHT_PROT in lwipopts.h
However first I was hoping for someone more familiary with LwIP mutual exclusion intricacies to clarify whether enabling LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT is also necessary.
I've enabled both and pbuf/memp corruption is gone for good, but havent (and can't afford at the moment) to do extensive testing with just SYS_LIGHTWEIGHT_PROT enabled. The point is that according to LwIP documentation enabling LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT can increase interrupt latency significantly, so it is certainly worth to find out whether it is necessary.
Also, not that I provided an alternative fix: use pbuf_alloc_callback() and pbuf_free_callback() instead of pbuf_alloc() / pbuf_free(). That would work for sure and not require any changes to lwipopts.h, but again, I would appreciate if some LwIP expert could chip in and provide advice on which is the best fix.
No clues about this?
Please note that it is out of the question whether this is a bug or not. ChibiOS demos, as shipped, will cause pbuf corruption due to pbuf alloc/free being done from the LwIP data pump thread (lwipthread.c) with SYS_LIGHTWEIGHT_PROT disabled.
We need someone knowledgeable about the LwIP internals to tell whether SYS_LIGHTWEIGHT_PROT enabled will suffice or LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT enabled is also necessary.
My guess is that just SYS_LIGHTWEIGHT_PROT is necessary so thee is proper mutual exclusion when allocating/freeing pbuf. LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT is only necessary if alloc/free is done from interrupt context or something.
The problem is that I don't know for sure, SYS_LIGHTWEIGHT_PROT should use critical zones instead of mutexes for synchronization so it should work either way because the arch layer supplies both mechanisms.
iggarpe wrote:My guess is that just SYS_LIGHTWEIGHT_PROT is necessary so thee is proper mutual exclusion when allocating/freeing pbuf. LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT is only necessary if alloc/free is done from interrupt context or something.
I don't claim to have any great knowledge in this area; however having been experimenting with lwIP (V2.0.2) I agree with your interpretation. I've been testing with this combination of options, mostly on a 32F429, using the sockets interface, and found it works OK. I'll try and remember to test without SYS_LIGHTWEIGHT_PROT set to see if it makes a difference.
Have just tested with SYS_LIGHTWEIGHT_PROT set to zero, and the system did indeed crash (although it took rather longer than I expected, given that the network interface was running close to flat out). So can confirm SYS_LIGHTWEIGHT_PROT set to 1
