hal_files.h error in fileStreamGetSize: ')' at wrong place Topic is solved
mumme
Post by mumme »
Hi!
I'm using 19.1.3, but it is the same in master.
Compile error In macro fileStreamGetSize:
../../../ChibiOS-git/os/hal/include/hal_files.h:210:40: error: too few arguments to function 'dtcFile->vmt->getsize'
 #define fileStreamGetSize(ip, offset) ((ip)->vmt->getsize(ip), offset)
I expect it to be: (moved parenthesis)
 #define fileStreamGetSize(ip, offset) ((ip)->vmt->getsize(ip, offset))
Is this correct?
Seems to work fine when i move the parenthesis.
Re: hal_files.h error in fileStreamGetSize: ')' at wrong place
Thanks, that interface is not yet used, will fix it.
Fixed as bug #1040.
faisal
Has thanked: 45 times
Been thanked: 62 times
Post by faisal »
mumme wrote:Hi!
Is this correct?
Are you using this interface? Care to share how you're using it?
