GCC10 / 9 inline functions weird behavior Topic is solved
error414
Has thanked: 3 times
Post by error414 »
I use newest chibios from github downloaded from master yesterday (27.01.2021), because I read viewtopic.php?f=35&t=5678, unfortunately new version of chibios didn't solve the issue. I'm new in IoT programming so I have no clue how to fix it right way.
Issue:
unhandled exception if program is compiled with -O2 or -Os flag see "unhandled_exception.png". With "-Og" it works like a charm.
Inline optimalization log "-O2 -fopt-info-inline-all" https://pastebin.com/UPqmp9rp .
It works if I add "NOINLINE" to lines https://github.com/ChibiOS/ChibiOS/blob ... .h#L91-L92
NOINLINE void __tm_calibration_init(tm_calibration_t *tcp);
   NOINLINE void chTMObjectInit(time_measurement_t *tmp);
or add " -fno-inline " flag. Flag "-finline-small-functions" does not work at all.
I tested three toolchains:
gcc-arm-none-eabi-10-2020-q4-major-win32 - does not work
gcc-arm-none-eabi-9-2019-q4-major-win32 - does not work
gcc-arm-none-eabi-7-2017-q4-major-win32- works
Board: nucleo F401RE
Devel platform: win10
I reduced program to simple shell tests:
static const ShellConfig shell_cfg1 = {
(BaseSequentialStream *)&SD2,
shell_local_commands
* Application entry point.
int main(void) {
shellInit();
while (true) {
thread_t *shelltp = chThdCreateFromHeap(NULL, 800,
"shell", NORMALPRIO + 50,
shellThread, (void *)&shell_cfg1);
chThdWait(shelltp);
chThdSleepMilliseconds(150);
palClearPad(GPIOA, GPIOA_LED_GREEN);
chThdSleepMilliseconds(100);
palSetPad(GPIOA, GPIOA_LED_GREEN);
chThdSleepMilliseconds(100 );
BTW: I use LGVL as well (but for test was removed) and it does not work at all too with GCC10 and 9 and "-O2". I didn't figure out how to fix it. ChibiOs is much more friendly for debugging. Nice piece of SW.
Re: GCC10 / 9 inline functions weird behavior
Have you enabled debug options in chconf.h? especially stack overflow checking.
error414
Post by error414 »
OMG, yes I had all debug options turned on :(. I disabled all and it works now.
Sorry I wasted your time ;(, it was stupid issue.
It could be simply a stack overflow, changing compiler and OS options can change stack usage.
error414
Post by error414 »
Thank you very much for help. The result:
1) chibistudio + make = just works
2) clion + cmake = does not work even if I used toolchain from chibistudio or WSL, ....
3) clion + make = works if I use makefile from demo and modify it to my project
I tried grab all settings from Makefile, but it still does not work, cmake is magic black box, not as make.
I am an old fashioned make guy. Probably you are not doing everything you see in makefiles, check the compiler command like options in the log and compare the two.
error414
Post by error414 »
Three days studying of make file. Finnaly it works as I want even with cmake. It was not chibios fault, just cmake is for head ache.
Big thanks for help.
