mdma driver error handling Topic is solved
alex31
Has thanked: 38 times
Been thanked: 62 times
Postby alex31 » Wed Jul 07, 2021 10:28 am
I am writing a MDMA user level driver, using the existing low level code already written on ChibiOS.
I have a little problem withe the error handling : when the mdma detect an error, it writes CESR (Channel Error Status Register) with bits corresponding to different kind of error, set bit TEIF in CISR code, and trigger ISR. When error bit is cleared writing CTEIF in CIFCR register, that also clear the CESR register containing the error code.
for now the ISR is written like that :
static void mdma_serve_interrupt(const stm32_mdma_channel_t *mdmachp) {
  uint32_t flags;
  flags = mdmachp->channel->CISR;
  mdmachp->channel->CIFCR = flags; // clear Error Status Register
  if (mdmachp->func != NULL) {
    mdmachp->func(mdmachp->param, flags);
The problem is that the CESR register is cleared before call to handling code.
Is is possible to move the
line at the end of the function, after the call to the handler ?
I have tested that it resolves my problem, but I don't know if the change is compatible with WSPI which is for now the only ChibiOS driver that use MDMA low level API.
Alexandre
alex31
Re: mdma driver error handling
Postby alex31 » Wed Jul 07, 2021 3:12 pm
Another solution could be to pack all the useful bits from CISR (6 bits) and the useful bits of CESR (12 bits) in the 32 bits parameter flags.
A.
Has thanked: 1076 times
Been thanked: 922 times
Postby Giovanni » Wed Jul 07, 2021 5:34 pm
Moving this in bug reports.
Postby Giovanni » Fri Mar 18, 2022 1:29 pm
I placed this change in trunk: CISR in lower 16 bits, CESR in upper 16 bits.
Let me know how it goes, I could backport this if needed.
alex31
Postby alex31 » Sun Mar 20, 2022 3:15 pm
It's Ok for me, and yes, I am interested by a 21.11 backport.
Alexandre
Return to “Bug Reports”
Users browsing this forum: No registered users and 12 guests
