RP watchdog bug Topic is solved
szilveszter
Has thanked: 9 times
Been thanked: 5 times
RP watchdog bug
Post by szilveszter »
I discovered a bug (or at least a not expected behaviour) in rp2040's watchdog driver. At the driver initialization it calculates the LOAD register's value from the config's `lrl` value (delay in ms) with a certain formula coming from the PICO SDK, but at the reseting it directly applies the `lrl` value (delay in ms) and causes inconsistencies. I have a commit which fixes this, I wonder if you accept it somewhere as a PR or rather fix it yourself?
Here is the commit, it helps to understand what I am talking about: https://github.com/ChibiOS/ChibiOS/compare/master...zsigmondszilveszter:ChibiOS:pr/RP-WDG-bugfix
FXCoder
Has thanked: 188 times
Been thanked: 134 times
Re: RP watchdog bug
Post by FXCoder »
Thanks for the report.
Slightly different fix now applied to trunk on SF.
Please give it a test (don't have a Pico board handy at the moment).
Bob
szilveszter
Re: RP watchdog bug
I am not that familiar with SVN. How and from where could I pull the code ?
Szilveszter
FXCoder
Re: RP watchdog bug
Post by FXCoder »
Here you go...
It will turn up on the GIT mirror also (whenever it syncs)
Also note there is now a patch submission site which can be found at…
https://review.chibios.org
RP_WDG.zip
(2.9 KiB) Downloaded 603 times
szilveszter
Re: RP watchdog bug
../ChibiOS/os/hal/ports/RP/LLD/WDGv1/hal_wdg_lld.c: In function 'set_wdg_counter':
../ChibiOS/os/hal/ports/RP/LLD/WDGv1/hal_wdg_lld.c:55:19: error: 'wdgp' undeclared (first use in this function); did you mean 'wdgStop'?
   55 |   uint32_t time = wdgp->config->rlr;
      |                   wdgStop
The 'wdgp' has to be passed to the function or the global 'WDGD1' should be used.
szilveszter
Re: RP watchdog bug
The watchdog driver also needs to set something in the the PSM's (Power-on State Machine) WDSEL register, otherwise the watchdog doesn't reset anything.
Something like this:
// reset everything apart from ROSC and XOS
 PSM->WDSEL = _u(0x1FFFC);
Here is my Commit for an example.
FXCoder
Re: RP watchdog bug
Post by FXCoder »
Thanks for working on this.
I will find my RP2040s and set up for test soon.
In the mean time here is an updated driver.
Bob
RP_WDG.zip
(3.01 KiB) Downloaded 651 times
szilveszter
Re: RP watchdog bug
It works now as expected. Thank you for the fix.
Szilveszter
FXCoder
Re: RP watchdog bug
Post by FXCoder »
Trunk now updated.
This report can be closed.
