Hi!
I just found out that by enabling CH_DBG_SYSTEM_STATE_CHECK, at first switch to a thread in chSysInit() and calling chThdSleepMilliseconds() the OS is halted, because nil.lock_cnt == 1.
Version 17.6.0
I am pretty sure, this is not due to my stuff.
Kind regards,
Klaus
CH_DBG_SYSTEM_STATE_CHECK => chSysHalt Topic is solved
Re: CH_DBG_SYSTEM_STATE_CHECK => chSysHalt
I am trying the demo NIL-STM32F746G-DISCOVERY with state checker enabled. It does not trigger the problem. Could you share a minimal project that I could test?
Moving this topic in "bug reports".
Hi!
Sorry, I think I have more problems than I thought, and most of them have to do with the Tasking comiler/linker.
I have a SysTick_Handler, that shall do the scheduling during CH_IRQ_EPILOGUE().
In _port_irq_epilogue a new exception return context is created, but it does not branche neiter to _port_switch_from_isr nor to _port_exit_from_isr but returns to the idle thread. (I have only one thread.)
But it shall return from the ISR to _port_switch_from_isr or to _port_exit_from_isr, right?
Kind regards,
Klaus
Kind regards,
Klaus
Correct, ISRs can have two enforced return points, the ones you mentioned.
Users browsing this forum: No registered users and 71 guests
