Documentation for rescheduling requirements for S/I class APi Topic is solved
faisal
Has thanked: 44 times
Been thanked: 60 times
Postby faisal » Fri Apr 10, 2020 12:19 am
You had language similar to this in previous documentation:
–“S” is a function that must be called from within a critical zone and can reschedule internally
–“I” is a function that must be called from within a critical zone and does not reschedule internally
However, in the current documentation there is no explicit mention that S class functions reschedule internally, while no I class functions reschedule. Someone very experienced may be able to infer this from the documentation, but this is something worth mentioning right in the beginning when explaining kernel and API concepts.
Has thanked: 1074 times
Been thanked: 921 times
Re: Documentation for rescheduling requirements for S/I class APi
Postby Giovanni » Fri Apr 10, 2020 8:40 am
I will check, it is not supposed to be this way. Moving to bug reports.
faisal
Postby faisal » Sat Apr 11, 2020 5:10 pm
Thanks for looking into it. I believe it should have been here:
http://chibiforge.org/doc/20.3/rt/concepts.html
Postby Giovanni » Wed Apr 29, 2020 9:34 am
I added some notes, the confusion was originated because there were two copies of concepts.dox. Moved in a common location.
Return to “Bug Reports”
Users browsing this forum: No registered users and 18 guests
