ADCv3 and ADCv4 Analog Watchdog
FXCoder
Has thanked: 168 times
Been thanked: 120 times
Postby FXCoder » Fri May 22, 2020 1:33 am
Hi.
Seems that AWD support is only partially implemented in the ADCv3 and ADCv4 drivers.
So this is just a placeholder bug report at the moment pending implementation work yet to be done.
Bob
For example code in hal_adc_lld.c of ADCv4 at line 550...
  /* ADC setup, if it is defined a callback for the analog watch dog then it
     is enabled.*/
  adcp->adcm->ISR   = adcp->adcm->ISR;
  adcp->adcm->IER   = ADC_IER_OVRIE | ADC_IER_AWD1IE;
And hal_adc_lld.c of ADCv3 at line 850...
     is enabled.*/
  adcp->adcm->TR1   = grpp->tr1;
Also to be added callback fields in config and fields for TR2/3 (with any MCU conditional configuration).
Has thanked: 861 times
Been thanked: 743 times
Re: ADCv3 and ADCv4 Analog Watchdog
Postby Giovanni » Sat Feb 13, 2021 10:35 am
bump
FXCoder
Postby FXCoder » Wed Feb 17, 2021 1:14 am
Did some work on ADCv4 patch which needs your review to see if I am on the right track.
1. Add new config fields for AWD2,3
2. Add handling for slave mode of above
3. Revise lld_start WRT setup for above
4. Revise handling in interrupt to process dual mode.
5. Probably needs some conditionals for H7 variants which remains TBI/TBD.
Do not have an H7 board on hand for testing ATM.
Bob
ADCv4_AWD_patch.zip
(1.99 KiB) Downloaded 23 times
Return to “Bug Reports”
