This could be it, moving in "bug reports".
EXTI PVM Wakeup Topic is solved
- FXCoder
- Has thanked: 180 times
- Been thanked: 130 times
Re: EXTI PVM Wakeup
The bug is actually in line 83 of stm32_exti16-35_38.inc
STM32_EXTI163538_HANDLER should be STM32_EXTI1635_38_HANDLER .
Martin,
Do you have compile warnings disabled?
Bob
Martin,
Bob
#if !defined(STM32_DISABLE_EXTI1635_38_HANDLER)
* @brief EXTI[16], EXTI[35], EXTI[38] interrupt handler.
* @isr
OSAL_IRQ_HANDLER(STM32_EXTI163538_HANDLER) {
uint32_t pr;
OSAL_IRQ_PROLOGUE();
Re: EXTI PVM Wakeup
This causes the ISR to not be linked to the vector and explains the problem, the IRQ goes in unhandled because of this.
Easy fix.
Easy fix.
Re: EXTI PVM Wakeup
Hey Bob,
no, ive not disable the compile warnings. Do you know, what is the bug in stm32_exti16-35_38.inc?
in my debugging session ill only jump in vectorF4 and than in unhandled exeption. You mean stm32_exti19_21.inc, right?
But this exti lines are not use in my case and will be not used, if we not defined STM32_EXTI19_IS_USED or STM32_EXTI20_IS_USED.
@Giovanni which register do you mean?
Martin
Martin
Re: EXTI PVM Wakeup
sprehse wrote:@Giovanni which register do you mean?
Martin
Don't worry, what Bob found already explains the problem.
- alex31
- Has thanked: 38 times
- Been thanked: 62 times
Re: EXTI PVM Wakeup
associating the ISR fonction with a macro in mcuconf.h is OK, but there is no prototype declaration of the function prior it's use, where is it clean to declare the prototype ?
In the macro ?
#define STM32_EXTI21_ISR(x,y) void isrT60Meas(void); isrT60Meas()
or is there a clever / cleaner way to do it ?
Thanks
Alexandre
In the macro ?
Thanks
Alexandre
Users browsing this forum: No registered users and 55 guests
