STM32G431 DMA defines error Topic is solved
mobyfab
Has thanked: 21 times
Been thanked: 30 times
Postby mobyfab » Fri Mar 19, 2021 11:36 am
Ciao!
There is some missing logic in the G431 DMA defines.
STM32_DMA1_CH8_HANDLER and STM32_DMA1_CH8_HANDLER are defined but not their streams which results in
ChibiOS/os/hal/ports/STM32/LLD/DMAv1/stm32_dma.c: In function 'Vector1CC':
ChibiOS/os/hal/ports/STM32/LLD/DMAv1/stm32_dma.c:542:21: error: 'STM32_DMA2_STREAM8' undeclared (first use in this function); did you mean 'STM32_DMA2_STREAM1'?
  542 |   dmaServeInterrupt(STM32_DMA2_STREAM8);
      |                     STM32_DMA2_STREAM1
STM32_DMA1_CH7_HANDLER and STM32_DMA1_CH8_HANDLER should not be defined in this case
Same thing with DMA2.
This applies on stable_20.3.x and master
edit: it seems like for other platforms these are defined in stm32_registry.h, here it's in stm32_isr.h
Has thanked: 1076 times
Been thanked: 922 times
Re: STM32G431 DMA defines error
Postby Giovanni » Sat Apr 24, 2021 7:01 am
Fixed as bug #1155.
Return to “Bug Reports”
Users browsing this forum: No registered users and 67 guests
