Stack overflow check improvements Topic is solved
dismirlian
Been thanked: 16 times
Postby dismirlian » Tue Apr 20, 2021 4:07 pm
Hi all,
The ARM-v7m code for stack overflow detection does the following:
    #define port_switch(ntp, otp) do {                                      \
      struct port_intctx *r13 = (struct port_intctx *)__get_PSP();          \
      if ((stkalign_t *)(r13 - 1) < (otp)->wabase) {                        \
        chSysHalt("stack overflow");                                        \
      __port_switch(ntp, otp);                                              \
    } while (0)
It can be seen that, when a thread is switched out, the switch code check the current value of the PSP, and compares it with the base of the thread's stack. If it's lower, then a stack overflow occurred.
The problem with this method is that we can't detect if the stack was corrupted and then the PSP returned to the correct reserved area before the context switch. Maybe a better approach would be to add a guard (single word) to the stack, and check its value. As a proof of concept, I did:
      if ((*(const uint8_t *)((otp)->wabase) != CH_DBG_STACK_FILL_VALUE) {  \
    } while (0)
With this modification in place ChibiOS detected a stack corruption that was previously unnoticed.
Thanks,
Diego.
Re: Stack overflow check improvements
Postby Giovanni » Tue Apr 20, 2021 5:15 pm
It is a good idea, perhaps combine both because a stack could skip the guard word without changing it.
Note that there is also an hard check using the MPU on the armv7-m port.
dismirlian
Postby dismirlian » Tue Apr 20, 2021 5:42 pm
Hi Giovanni, combining both is a good idea.
Yes, I've turned on PORT_ENABLE_GUARD_PAGES. It didn't work at first, but that was because I didn't turn on the MPU manually (mpuEnable(MPU_CTRL_PRIVDEFENA_Msk)).
Some thoughts:
- Would it be possible for ChibiOS to turn on the MPU automatically if PORT_ENABLE_GUARD_PAGES is TRUE?
- For MCUs that have a MPU, would it be sensible to default to PORT_ENABLE_GUARD_PAGES = TRUE when CH_DBG_ENABLE_STACK_CHECK is TRUE? I know the unhandled exception would be less friendly for developers, but the runtime cost for stack checking would be zero.
Thanks,
Diego.
Postby Giovanni » Tue Apr 20, 2021 6:46 pm
dismirlian wrote:Yes, I've turned on PORT_ENABLE_GUARD_PAGES. It didn't work at first, but that was because I didn't turn on the MPU manually (mpuEnable(MPU_CTRL_PRIVDEFENA_Msk)).
This is a regression in trunk and 20.x, it is supposed to enable it, it was OK in 19.x.
I am moving this topic in "bug reports" so it is not forgotten...
dismirlian
Postby dismirlian » Wed Apr 21, 2021 12:42 am
Great, thanks Giovanni.
steved
Has thanked: 12 times
Been thanked: 135 times
Postby steved » Wed Apr 21, 2021 4:13 pm
Giovanni wrote:This is a regression in trunk and 20.x, it is supposed to enable it, it was OK in 19.x.
Possible "tidy-up" while you're there - the F7 and H7 ports define and use MPU_CTRL_PRIVDEFENA, which has the same value as MPU_CTRL_PRIVDEFENA_Msk (defined in CMSIS files); although the first is type 'UL' and the second is type 'L'.
dismirlian
Postby dismirlian » Mon May 03, 2021 11:59 pm
As a minor related problem, the ChibiOS eclipse plugin incorrectly reports free stack if PORT_ENABLE_GUARD_PAGES is enabled (it counts the guard bytes as "available").
Postby Giovanni » Tue May 04, 2021 6:02 am
dismirlian wrote:As a minor related problem, the ChibiOS eclipse plugin incorrectly reports free stack if PORT_ENABLE_GUARD_PAGES is enabled (it counts the guard bytes as "available").
Yes, currently there is no way, for the debugger plugin, to know that the MPU is in use. The plugin is not CPU-architecture-aware.
dismirlian
Postby dismirlian » Tue May 04, 2021 11:47 am
Yes, but what if wabase is set to tdp->wbase + PORT_GUARD_PAGE_SIZE?
Would this have any unwanted side-effect?
Postby Giovanni » Tue May 04, 2021 12:52 pm
dismirlian wrote:Yes, but what if wabase is set to tdp->wbase + PORT_GUARD_PAGE_SIZE?
Yes, several actually, dynamic treads for example.
Return to “Bug Reports”
Users browsing this forum: Bing [Bot] and 41 guests
