GCC10 linker warning Topic is solved
steved
Has thanked: 12 times
Been thanked: 135 times
Postby steved » Mon Apr 26, 2021 1:26 pm
Using GCC 10.2.1, Chibi 20.3 with a reasonably straightforward application (on 32F091 at present, but seen on other processors as well) I get the following harmless warning during compilation:
lto-wrapper.exe: warning: Options to Xassembler do not match: -alms=Build/lst/crt1.lst, -alms=Build/lst/hal.lst, dropping all -Xassembler and -Wa options.
Makefile options that may be relevant (or different to the demos):
USE_LDOPT = -lstdc++ -lm -Wl,--wrap,_malloc_r -Wl,--wrap,atexit
USE_OPT = -O0 -ggdb -fomit-frame-pointer -falign-functions=16
USE_CPPOPT = -fno-rtti -fno-non-call-exceptions -fno-exceptions -fno-threadsafe-statics -fno-use-cxa-atexit
USE_LTO = yes
USE_SMART_BUILD = yes
Re: GCC10 linker warning
Postby Giovanni » Mon Apr 26, 2021 1:33 pm
The difference is the .lst file name which of course is wrong, try removing that option (or fake always the same file name) and it will disappear.
Cannot be fixed because it is a compiler bug IMHO, not sure if it has already been reported.
Thargon
Has thanked: 15 times
Been thanked: 24 times
Postby Thargon » Tue Dec 07, 2021 5:22 pm
The issue still persists with ChibiOS 20.11.x and GCC 10.3. Is there any news regarding this topic?
Without LTO, my code does not fit for some small MCUs, while it does when I compile it with GCC 9. I'd like to upgrade the toolchain, but this issue holds me back.
Postby Giovanni » Tue Dec 07, 2021 5:32 pm
Giovanni wrote:Hi,
ych
Has thanked: 7 times
Been thanked: 9 times
Postby ych » Sun Mar 03, 2024 11:11 am
Giovanni wrote:... try removing that option (or fake always the same file name) and it will disappear. ...
Could you please clarify what exact option you mean to remove?
See the same warning on building RT-STM32F413ZH-NUCLEO144 demo from stable_21.11.x branch:
$ make
Linking build/ch.elf
lto-wrapper: warning: Options to '-Xassembler' do not match: -alms=./build/lst/crt1.lst, -alms=./build/lst/hal.lst, dropping all '-Xassembler' and '-Wa' options.
lto-wrapper: warning: using serial compilation of 2 LTRANS jobs
lto-wrapper: note: see the '-flto' option documentation for more information
With the following GCC version:
$ arm-none-eabi-gcc --version
arm-none-eabi-gcc (Arm GNU Toolchain 13.2.rel1 (Build arm-13.7)) 13.2.1 20231009
Copyright (C) 2023 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Postby Giovanni » Sun Mar 03, 2024 4:39 pm
You need to edit rules.mk, find -alms=xxxxx and remove it.
Note that the linker works also with the warning.
Return to “Bug Reports”
Users browsing this forum: No registered users and 69 guests
