chSysPolledDelay not looping with high level optimisation Topic is solved
alex31
Has thanked: 38 times
Been thanked: 62 times
Postby alex31 » Thu Apr 29, 2021 9:48 am
I have a problem with recent version of gcc (10.x and above (11.x) if I compile with -Ofast and lto (gcc10) and even with -Os and lto (gcc11)
Don't really understand the problem, but the loop exits early, so chSysPolledDelay does not wait for the desired time.
If I a add dummy variable setting in the loop like :
static volatile uint32_t dummyCnt=0U;
void chSysPolledDelayX(rtcnt_t cycles) {
  rtcnt_t start = chSysGetRealtimeCounterX();
  rtcnt_t end  = start + cycles;
  while (chSysIsCounterWithinX(chSysGetRealtimeCounterX(), start, end)) {
    dummyCnt++;
the problem is resolved (of course that is not a fix, just a clue to search for proper way of fixing)
I also tried to see the assembly output with compiler explorer, but with my limited arm ISA knowledge, i don't spot any obvious compiler issue in the generated code :
assembly output
edit 1/
can see the effect in the timing of driving pins in a big project, but not able to reproduce the problem with a small example, keep searching ...
Alexandre
alex31
Re: chSysPolledDelay not looping with high level optimisation
Postby alex31 » Thu Apr 29, 2021 1:56 pm
Still no able to reproduce the problem with a simple example, so it's probably a side effect in my app, not a compiler problem, so
consider this post useless for now.
Sorry for the noise.
A.
Postby Giovanni » Thu Apr 29, 2021 2:05 pm
volatile rtcnt_t CYCCNT = 1000U;
rtcnt_t chSysGetRealtimeCounterX() {
    return CYCCNT;
CYCCNT should be an HW counter, why is it a variable in your example?
alex31
Postby alex31 » Thu Apr 29, 2021 3:06 pm
It would have been too complicated to compile chibios within compiler explorer, so I have simulated the hardware counter with a volatile variable to see what the compiler does. In fact, I have dig a little bit, and I am able to fix the problem with a
asm volatile("": : :"memory")
between polledDelay and the reading of a pin (for the record, the problem is with the community hd44780 lcd library when compiled with Ofast).
Alexandre
Return to “Bug Reports”
Users browsing this forum: No registered users and 64 guests
