the shell needs to disable some calls on NIL that only work on RT. These are guarded by checks for _CHIBIOS_NIL_. But since NIL 4.0 the define changed to __CHIBIOS_NIL__ with 2 underscores. This means the current code doesn't compile anymore.
The attached patch fixes this. Afterwards I was not only able to compile it, but I also confirmed that the shell still works on NIL. Please consider applying the attached patch.
[PATCH] shell fails to compile on NIL, still using _CHIBIOS_NIL_ Topic is solved
- Been thanked: 17 times
- nil-shell.zip
- zipped patch
- (1.38 KiB) Downloaded 123 times
