hal_sio_lld.c source directory confusion Topic is solved
resset
Has thanked: 2 times
Postby resset » Mon Jul 05, 2021 12:01 pm
My setup:
- ChibiOS version or subversion revision number: 21.6.0
- Compiler: GCC 10.3.0
- Platform and board: STM32H743VI, but NUCLEO144 with STM32H743ZI is also affected
I am trying to use SIO with FIFO on H7 platform. os/hal/ports/STM32/STM32H7xx/platform.mk says that this MCU family uses USARTv3 and its driver.mk file is being indeed included. However, during the compilation I can see that hal_sio_lld.c from the USARTv2 version is compiled instead:
arm-none-eabi-gcc -c -mcpu=cortex-m7 -mthumb -O2 -ggdb -fomit-frame-pointer -falign-functions=16 -ffunction-sections -fdata-sections -fno-common -flto  -Wall -Wextra -Wundef -Wstrict-prototypes -Wa,-alms=./build/lst/hal_sio_lld.lst -DCORTEX_USE_FPU=FALSE -DSTM32_ENFORCE_H7_REV_XY     -MD -MP -MF ./.dep/hal_sio_lld.o.d -I. -I./cfg -I../../../os/license -I../../../os/common/portability/GCC -I../../../os/common/startup/ARMCMx/compilers/GCC -I../../../os/common/startup/ARMCMx/devices/STM32H7xx -I../../../os/common/ext/ARM/CMSIS/Core/Include -I../../../os/common/ext/ST/STM32H7xx -I../../../os/hal/include -I../../../os/hal/ports/common/ARMCMx -I../../../os/hal/ports/STM32/STM32H7xx -I../../../os/hal/ports/STM32/LLD/ADCv4 -I../../../os/hal/ports/STM32/LLD/BDMAv1 -I../../../os/hal/ports/STM32/LLD/CRYPv1 -I../../../os/hal/ports/STM32/LLD/DACv1 -I../../../os/hal/ports/STM32/LLD/DMAv2 -I../../../os/hal/ports/STM32/LLD/EXTIv1 -I../../../os/hal/ports/STM32/LLD/FDCANv1 -I../../../os/hal/ports/STM32/LLD/GPIOv2 -I../../../os/hal/ports/STM32/LLD/I2Cv3 -I../../../os/hal/ports/STM32/LLD/MACv2 -I../../../os/hal/ports/STM32/LLD/MDMAv1 -I../../../os/hal/ports/STM32/LLD/OTGv1 -I../../../os/hal/ports/STM32/LLD/QUADSPIv2 -I../../../os/hal/ports/STM32/LLD/SDMMCv2 -I../../../os/hal/ports/STM32/LLD/SPIv3 -I../../../os/hal/ports/STM32/LLD/RNGv1 -I../../../os/hal/ports/STM32/LLD/RTCv2 -I../../../os/hal/ports/STM32/LLD/SYSTICKv1 -I../../../os/hal/ports/STM32/LLD/TIMv1 -I../../../os/hal/ports/STM32/LLD/USART -I../../../os/hal/ports/STM32/LLD/USARTv3 -I../../../os/hal/ports/STM32/LLD/USARTv2 -I../../../os/hal/ports/STM32/LLD/xWDGv1 -I../../../os/hal/boards/ST_NUCLEO144_H743ZI -I../../../os/hal/osal/rt-nil -I../../../os/rt/include -I../../../os/oslib/include -I../../../os/common/portability/GCC -I../../../os/common/ports/ARM-common -I../../../os/common/ports/ARMv7-M -I../../../test/lib -I../../../test/rt/source/test -I../../../test/oslib/source/test ../../../os/hal/ports/STM32/LLD/USARTv2/hal_sio_lld.c -o build/obj/hal_sio_lld.o
I think the reason is that hal_sio_lld.c has the same name in v3 and v2 and makefiles work in a particular way. SRCPATHS list is created in the os/common/startup/ARMCMx/compilers/GCC/mk/rules.mk file using `sort` instruction. This places UARTv2 directory before UARTv3. SRCPATHS is then copied to VPATH variable. According to the make documentation, it is used to search source files in "order in which directories are listed". This is how I get v2 LLD instead of v3 pointed by its driver.mk.
How to reproduce:
Compile RT-STM32H743ZI_REV_XY-NUCLEO144 demo with HAL_USE_SIO == TRUE in cfg/halconf.h and e.g. STM32_SIO_USE_USART2 == TRUE in cfg/mcuconf.h. There is no need to change anything else. Expected error message:
../../../os/hal/ports/STM32/LLD/USARTv2/hal_sio_lld.c: In function 'sio_lld_serve_interrupt':
../../../os/hal/ports/STM32/LLD/USARTv2/hal_sio_lld.c:759:14: error: 'USART_ISR_RXNE' undeclared (first use in this function); did you mean 'USART_ISR_NE'?
  759 |       (isr & USART_ISR_RXNE) != 0U) {
      |              USART_ISR_NE
../../../os/hal/ports/STM32/LLD/USARTv2/hal_sio_lld.c:759:14: note: each undeclared identifier is reported only once for each function it appears in
../../../os/hal/ports/STM32/LLD/USARTv2/hal_sio_lld.c:787:14: error: 'USART_ISR_TXE' undeclared (first use in this function); did you mean 'USART_ISR_TXFE'?
  787 |       (isr & USART_ISR_TXE) != 0U) {
      |              USART_ISR_TXFE
make: *** [../../../os/common/startup/ARMCMx/compilers/GCC/mk/rules.mk:190: build/obj/hal_sio_lld.o] Error 1
I can think of three solutions here: to rename v3 SIO files, to change makefile sources directory list creation or to further divide v2 and v3 version to avoid mixup. I have not enough expertise to say what should be the final fix though.
Mateusz
Has thanked: 1076 times
Been thanked: 922 times
Re: hal_sio_lld.c source directory confusion
Postby Giovanni » Mon Jul 05, 2021 12:29 pm
Thanks for finding, I think I will go for duplicating files and make v3 versions of everything.
Postby Giovanni » Thu Aug 19, 2021 10:46 am
Fixed as bug #1177.
Return to “Bug Reports”
Users browsing this forum: No registered users and 55 guests
