dmamux bug Topic is solved
tmentink
Postby tmentink » Wed Aug 11, 2021 10:45 am
I am working with a stm32L4S5 -> LLD DMAV1, and there is a bug in the dmaMux configuration.
If the STM has 7 DMA channels and make use of the DMAMUX, the 8th DMA channel will be configured incorrectly in the DMAMUX.
This is the old code
#define DMA1_CH1_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(0))
#define DMA1_CH2_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(1))
#define DMA1_CH3_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(2))
#define DMA1_CH4_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(3))
#define DMA1_CH5_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(4))
#define DMA1_CH6_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(5))
#define DMA1_CH7_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(6))
#define DMA1_CH8_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(7))
#define DMA2_CH1_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(8))
#define DMA2_CH2_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(9))
#define DMA2_CH3_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(10))
#define DMA2_CH4_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(11))
#define DMA2_CH5_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(12))
#define DMA2_CH6_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(13))
#define DMA2_CH7_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(14))
#define DMA2_CH8_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(15))
The DMAMux Channels will be one off if you are using more than 7 channels.
The following code will fix this issue.
#if STM32_DMA1_NUM_CHANNELS > 7
#define DMA2_CH1_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(0 + STM32_DMA1_NUM_CHANNELS))
#define DMA2_CH2_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(1 + STM32_DMA1_NUM_CHANNELS))
#define DMA2_CH3_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(2 + STM32_DMA1_NUM_CHANNELS))
#define DMA2_CH4_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(3 + STM32_DMA1_NUM_CHANNELS))
#define DMA2_CH5_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(4 + STM32_DMA1_NUM_CHANNELS))
#define DMA2_CH6_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(5 + STM32_DMA1_NUM_CHANNELS))
#define DMA2_CH7_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(6 + STM32_DMA1_NUM_CHANNELS))
#define DMA2_CH8_VARIANT            ((DMAMUX_Channel_TypeDef *)DMAMUX1_CHANNEL(7 + STM32_DMA1_NUM_CHANNELS))
Re: dmamux bug
Postby Giovanni » Wed Aug 11, 2021 3:40 pm
Thanks for finding.
Re: dmamux bug
Postby Giovanni » Thu Aug 19, 2021 10:17 am
Fixed as bug #1176.
Return to “Bug Reports”
Users browsing this forum: No registered users and 71 guests
