Support for STM32G0B1 Topic is solved
Has thanked: 1076 times
Been thanked: 922 times
Re: Support for STM32G0B1
Postby Giovanni » Tue Nov 07, 2023 9:50 am
Could you post your halconf.h, mcuconf.h files causing compilation errors?
charlesrwest
Postby charlesrwest » Tue Nov 07, 2023 3:28 pm
Certainly.
For reference, the RT-STM32G0B1RE-NUCLEO64 demo exhibits this behavior.
With a fresh copy and the only change being the ChibiOS directory path it compiles fine.
► Show Spoiler
If you make the further changes:
#define HAL_USE_PWM TRUE
and
#define STM32_GPT_USE_TIM3 TRUE
#define STM32_GPT_USE_TIM4 TRUE
then it fails with
► Show Spoiler
Those being the only differences confirmed by recursive diff:
► Show Spoiler
I have also attached the project. Thanks.
RT-STM32G0B1RE-NUCLEO64_tim3_tim4.zip
(14.9 KiB) Downloaded 72 times
Postby Giovanni » Wed Nov 08, 2023 9:36 am
Fixed in repository trunk.
charlesrwest
Postby charlesrwest » Thu Nov 09, 2023 3:48 pm
Thank you. I have verified that the TIM3, TIM4 PWM channels are working as expected on my board.
I cannot reproduce the PF3-4 PAL_MODE_INPUT_PULLUP causing crash bug in an isolated example based on the example in the trunk, so it was probably a mess up on my side (apologies). I will keep digging.
Thanks again. This really helps.
Return to “Bug Reports”
