This is interesting: https://community.nxp.com/t5/MPC5xxx/Wh ... d-p/922748
Perhaps creating a stub would be sufficient, initializations are already done in startups.
e200 broken in 21.6.x Topic is solved
- Has thanked: 21 times
- Been thanked: 30 times
Re: e200 broken in 21.6.x
it seems like creating an __eabi() or __init() stub works
Giving this a try...
btw, toolchain documentation is available here: https://www.nxp.com/docs/en/release-not ... 1-2-RN.pdf
--- extracted/gcc-4.9.4/libgcc/config/rs6000/t-e200.bkp 2021-09-26 23:45:07.848720330 +0200
+++ extracted/gcc-4.9.4/libgcc/config/rs6000/t-e200 2021-09-26 23:45:17.532808552 +0200
@@ -18,12 +18,3 @@
# We build {e,n}crti.o and {e,n}crtn.o, which serve to add begin and
# end labels to all of the special sections used when we link using gcc.
-# Assemble startup files.
-ecrti$(objext): $(srcdir)/config/rs6000/eabivle-ci.S
- $(crt_compile) -c $<
-ecrtn$(objext): $(srcdir)/config/rs6000/eabivle-cn.S
okay, so copying these 2 eabivle-c*.S files and compiling them with the demo works.
They are also compiled with GCC and placed in lib/gcc/powerpc-eabivle/4.9.4/ecrt*.o
I'm trying to figure out why they are ignored...
One option would be to add them to libgcc.a
Another would be to explicitly link with them.
Probably they are not included because the application does not use the default startup files, our custom startups should export __eabi() and/or __init() equivalents I suppose.
yes, a stub void __eabi() {}; does the job as well
I've updated the script to use newer versions where possible, so far so good but I have no hardware to test it.
