21.6.x branch, L422 RCC issue Topic is solved
tzarc
Been thanked: 5 times
Postby tzarc » Mon Oct 18, 2021 11:30 pm
Branch: ChibiOS 21.6.x stable
Compiler: arm-none-eabi-gcc 8.3.1
Platform/board: custom STM32L422KB, adapted from ST_NUCLEO32_L432KC
Failure: build errors --
./lib/chibios/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc: In function 'pll_init':
./lib/chibios/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc:179:44: error: 'RCC_PLLCFGR_PLLP_Pos' undeclared (first use in this function); did you mean 'RCC_PLLCFGR_PLLN_Pos'?
 #define STM32_PLLP                  (0U << RCC_PLLCFGR_PLLP_Pos)
./lib/chibios/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc:343:34: note: in expansion of macro 'STM32_PLLP'
                  STM32_PLLQEN  | STM32_PLLP   |
./lib/chibios/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc:179:44: note: each undeclared identifier is reported only once for each function it appears in
Was attempting to build against L422KB (well, L412KB but close enough), but can't do so as it seems as if it's configured incorrectly in the stm32_registry.h.
There is no PLLP on the chip (when looking at STM32CubeMX), though the stm32_registry.h says so.
I had to make two changes to get things to compile:
  • Setting STM32_RCC_PLL_HAS_P to FALSE
  • Seemingly changing STM32_PLLPEN to STM32_PLLPDIV, as the former was already defined in hal_lld.h.
I'm not sure if the second is correct -- PLLQ/PLLR etc. also look like they have the same issue with STM32_PLLPEN/STM32_PLLPDIV.
diff --git a/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc b/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc
index 2b3af669d5..9d649d288f 100644
--- a/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc
+++ b/os/hal/ports/STM32/LLD/RCCv1/stm32_pll.inc
@@ -222,7 +222,7 @@
 #else /* !STM32_RCC_PLL_HAS_P */
 #define STM32_PLLP                  0U
-#define STM32_PLLPEN                0U
+#define STM32_PLLPDIV               0U
 #endif /* !STM32_RCC_PLL_HAS_P */
diff --git a/os/hal/ports/STM32/STM32L4xx/stm32_registry.h b/os/hal/ports/STM32/STM32L4xx/stm32_registry.h
index ecb2efc5de..8fcb5dba41 100644
--- a/os/hal/ports/STM32/STM32L4xx/stm32_registry.h
+++ b/os/hal/ports/STM32/STM32L4xx/stm32_registry.h
@@ -353,7 +353,7 @@
 #define STM32_RCC_HAS_HSE                   TRUE
 #define STM32_RCC_HAS_PLL                   TRUE
-#define STM32_RCC_PLL_HAS_P                 TRUE
+#define STM32_RCC_PLL_HAS_P                 FALSE
 #define STM32_RCC_PLL_HAS_Q                 TRUE
 #define STM32_RCC_PLL_HAS_R                 TRUE
tzarc
Re: 21.6.x branch, L422 RCC issue
Postby tzarc » Tue Oct 19, 2021 10:28 am
Also noticed one other thing -- all L4xx boards have GPIOH as well. The L422 doesn't currently have it enabled in stm32_registry.h, and likely needs to be enabled in other MCUs as well as the L422.
EDIT: Looks like GPIOD, too.
Postby Giovanni » Thu Oct 21, 2021 10:38 am
Fixed as #1198.
Note, not fixed in 21.6.x branch because it will be recreated starting from trunk before next release.
JSStabl
Has thanked: 3 times
Been thanked: 2 times
Postby JSStabl » Tue Jan 25, 2022 11:56 am
Fix #1198 breaks compilation for all STM496 (and maybe even L4A6) with less than 169 pins, since they don't have a GPIOI.
Example Chip is the STM32L496Vx Series.
Is there an elegant way to fix this? Our workaround is to revert this commit (sorry I can't navigate sourceforge that well):
https://github.com/ChibiOS/ChibiOS/comm ... 616ee9458a
Postby Giovanni » Tue Jan 25, 2022 12:23 pm
JSStabl wrote:Fix #1198 breaks compilation for all STM496 (and maybe even L4A6) with less than 169 pins, since they don't have a GPIOI.
In which version? do you mind opening another topic? this one is about 21.6.x which is closed.
Return to “Bug Reports”
Users browsing this forum: No registered users and 67 guests
