SPI HAL v2 fails to compile without SPI_USE_SYNCHRONIZATION Topic is solved
nikiwaibel
Has thanked: 4 times
Been thanked: 12 times
Postby nikiwaibel » Tue Dec 14, 2021 9:32 pm
a new version of the SPI HAL was added in -r15007.
if the new driver is used without enabling SPI_USE_SYNCHRONIZATION, compilation fails due to wrong number of arguments in the define __spi_wakeup_isr() (which does nothing else then hiding/erasing the code). the following diff patches the relevant code line:
$ svn diff
Index: os/hal/include/hal_spi_v2.h
--- os/hal/include/hal_spi_v2.h   (revision 15244)
+++ os/hal/include/hal_spi_v2.h   (working copy)
@@ -382,7 +382,7 @@
   osalSysUnlockFromISR();                                                   \
 #else /* !SPI_USE_SYNCHRONIZATION */
-#define __spi_wakeup_isr(spip)
+#define __spi_wakeup_isr(spip, msg)
 #endif /* !SPI_USE_SYNCHRONIZATION */
nikiwaibel
Re: SPI HAL v2 fails to compile without SPI_USE_SYNCHRONIZATION
Postby nikiwaibel » Wed Jan 12, 2022 2:28 pm
gentle reminder: /trunk in -r15345 has not yet been fixed, as far as i can see …
Postby Giovanni » Wed Jan 12, 2022 2:32 pm
Don't worry, fixes come in batches, it will happen on the next "pass".
Postby Giovanni » Sat Jan 22, 2022 7:54 am
Fixed as bug #1213.
Return to “Bug Reports”
Users browsing this forum: No registered users and 74 guests
