I'm bumping into SV#8 errors since commit 47ada68.
This is related but not fixed by the other bug I just reported "CORTEX_FAST_PRIORITIES used before its definition".
Defining CORTEX_FAST_PRIORITIES to 0 or 1 in my chconf.h solves the issue, while value 2 generate SV#8 errors.
Hitting SV#8 since commit 47ada68 Topic is solved
Re: Hitting SV#8 since commit 47ada68 Topic is solved
Turns out I had a BDMA stream with IRQ priority 2. Lowering its priority to 3 fixed my issue with CORTEX_FAST_PRIORITIES set to 2.
Note to myself: use the OSAL_IRQ_IS_VALID_PRIORITY check...
Yes good idea to place checks
I will look into the other issue you reported.
