I have a problem where the external exti2 interrupt is not working. i work on bord stm32f769 i need 4 channel interrupt where i set on GPIOC 2,GPIOC 3,GPIOC 8,GPIOC 11. all interrupts work except GPIOC 2. i need enlightenment
thank you
ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
#include "ch.h"
// #include "rt_test_root.h"
// #include "oslib_test_root.h"
// #include "chprintf.h"
int xx=0;
// #define printf(fmt, ...)
// chprintf((BaseSequentialStream*)&SD1, fmt, ##__VA_ARGS__)
* This is a periodic thread that does absolutely nothing except flashing
* a LED.
(void)arg;
palSetPadMode(GPIOD,4,PAL_MODE_OUTPUT_PUSHPULL |PAL_STM32_OSPEED_HIGHEST);
palSetPadMode(GPIOC, 2U, PAL_MODE_INPUT_PULLDOWN);
while (true) {
// palToggleLine(PAL_LINE(GPIOD, 4U));
chThdSleepMilliseconds(500);
// palClearLine(PAL_LINE(GPIOD, 4U));
// chThdSleepMilliseconds(500);
static void button_cb(void *arg){
(void)arg;
chSysLockFromISR();
// xx++;
chSysUnlockFromISR();
* Application entry point.
int main(void) {
* System initializations.
* and performs the board-specific initializations.
* RTOS is active.
palEnablePadEvent(GPIOC, 2U, PAL_EVENT_MODE_RISING_EDGE);
palSetPadCallback(GPIOC, 2U, button_cb, NULL);
palEnableLineEvent(PAL_LINE(GPIOC, 3U), PAL_EVENT_MODE_RISING_EDGE);
palSetLineCallback(PAL_LINE(GPIOC, 3U), button_cb, NULL);
* ARD_D13 is programmed as output (board LED).
// palClearLine(LINE_ARD_D13);
// palSetLineMode(LINE_ARD_D13, PAL_MODE_OUTPUT_PUSHPULL);
// sdStart(&SD1, NULL);
* Creates the example thread.
* sleeping in a loop and check the button state.
while (true) {
// if (palReadLine(LINE_BUTTON_USER)) {
// // test_execute((BaseSequentialStream *)&SD1, &rt_test_suite);
// // test_execute((BaseSequentialStream *)&SD1, &oslib_test_suite);
// printf("data %d\r\n",xx);
