I2C v.1.0 discrepancy RM Topic is solved
alexblack
Been thanked: 32 times
Postby alexblack » Tue Jun 14, 2022 12:52 pm
Hi.
In current stable branch (21.11.2) there is I2C v.1 driver and it has discrepancy with Reference Manual:
"ChibiOS\os\hal\ports\STM32\LLD\I2Cv1\hal_i2c_lld.c"
252 static void i2c_lld_serve_event_interrupt(I2CDriver *i2cp) {
253   I2C_TypeDef *dp = i2cp->i2c;
254   uint32_t regSR2 = dp->SR2;
255   uint32_t event = dp->SR1;
But the Reference Manual for STM32F407 (for example) says:
"Page 858 <27.6.6> DM00031020_RM0090_STM32F4xx.pdf
Bit 1 ADDR: Address sent (master mode)/matched (slave mode)
This bit is cleared by software reading SR1 register followed reading SR2, or by hardware
when PE=0.
Thus, you must first read status register 1, then 2:
254   uint32_t event = dp->SR1;
255   uint32_t regSR2 = dp->SR2;
Has thanked: 1022 times
Been thanked: 873 times
Re: I2C v.1.0 discrepancy RM
Postby Giovanni » Tue Jun 14, 2022 1:08 pm
Moving in bug reports.
Edoardo1982
Been thanked: 4 times
Postby Edoardo1982 » Mon Sep 19, 2022 5:17 pm
alexblack wrote:Hi.
when PE=0.
SR1 is cleared reading SR2 at the end of event handler
  /* Clear ADDR flag. */
  if (event & (I2C_SR1_ADDR | I2C_SR1_ADD10))
    (void)dp->SR2;
There is no discrepancy with RM.
Edoardo
Re: I2C v.1.0 discrepancy RM  Topic is solved
Postby Giovanni » Wed Sep 21, 2022 5:28 pm
Is this agreed? if so I will close the ticket.
Return to “Bug Reports”
Users browsing this forum: Mbroek635 and 9 guests
