Write flash problem with the MFS driver.
Erdemege
Postby Erdemege » Mon Sep 05, 2022 12:08 pm
Hello everyone, I'm new to ChibiOS and embedded development. I'm trying to use the MFS driver to write and read to the flash memory. I use the mfsWriteRecord() function to write. I can successfully write and read one record with the driver, however, when I try to write for the second time to a different location (by changing the id parameter) I get an MFS_ERR_FLASH_FAILURE error. To understand the problem I used a debugger and realized that at hal_efl_lld.c
static inline flash_error_t stm32_flash_check_errors(EFlashDriver *eflp) {
  uint32_t sr = eflp->flash->SR;
  /* Clearing error conditions.*/
  eflp->flash->SR = sr & 0x0000FFFFU;
  /* Some errors are only caught by assertion.*/
  osalDbgAssert((sr & (FLASH_SR_FASTERR |
                       FLASH_SR_MISERR |
                       FLASH_SR_SIZERR)) == 0U, "unexpected flash error");
  /* Decoding relevant errors.*/
  if ((sr & FLASH_SR_WRPERR) != 0U) {
    return FLASH_ERROR_HW_FAILURE;
  if ((sr & (FLASH_SR_PGAERR | FLASH_SR_PROGERR | FLASH_SR_OPERR)) != 0U) {
    return eflp->state == FLASH_PGM ? FLASH_ERROR_PROGRAM : FLASH_ERROR_ERASE;
  return FLASH_NO_ERROR;
On here it returns FLASH_ERROR_PROGRAM at last if condition since the sr value is 168 which means my flash status registers' Bit 3 PROGERR, Bit 5 PGAERR and Bit 7 PGSERR are 1.
Am I using the mfsWriteRecord() function wrong? From what I understand from the documentation I just need to give unique id values for each different record. And of course, this id must be between 1 and MFS_CFG_MAX_RECORDS (32).
Re: Write flash problem with the MFS driver.
Postby Giovanni » Mon Sep 05, 2022 12:17 pm
You understanding is correct, it could be a problem in the flash driver.
Are you able to run the MFS test suite on your board? you should see failures in there too if it is an EFL problem, MFS_ERR_FLASH_FAILURE is a physical flash error.
It could also be an MFS configuration error, the 2 banks must be mapped on 2 physical flash sectors and not overlap.
Erdemege
Postby Erdemege » Mon Sep 05, 2022 2:34 pm
First of all, thank you so much for your fast response.
It can be a silly question to ask but I don't where to find the MFS test suite since I'm quite new to the whole of this.
I'm using NUCLEO-L476RG and written my MFSConfig like this:
const MFSConfig mfscfg1 = {
  .flashp           = (BaseFlash *)&EFLD1,
  .erased           = 0xFFFFFFFFU,
  .bank_size        = 4096U,
  .bank0_start      = 60U,
  .bank0_sectors    = 2U,
  .bank1_start      = 260U,
  .bank1_sectors    = 2U
If I understood the logic of the MSConfig this should be fine but I'm not sure.
Postby Giovanni » Mon Sep 05, 2022 2:42 pm
There is a demo under /testhal/STM32/multi/EFL-MFS which supports a similar board, configuration appears correct.
Those EFL drivers are all contributed so I cannot make an absolute statement but should be fine because made by people who use them.
Erdemege
Postby Erdemege » Tue Sep 13, 2022 10:31 am
Thank you so much for your answer.
I switched to the oldest release of the chibios (21.11.2). mfsStart function which I call at the beginning to use mfs driver directly gives me an MFS_ERR_INTERNAL error. What can cause this problem? It says internal logic failure but can you expand this please?
Thank you so much for your time and support.
Erdem
Postby Giovanni » Tue Sep 13, 2022 1:02 pm
That error can be caused by errors returned by the underlying EFL driver, moving this topic in "bug reports" but I cannot guarantee when I will be able to give it a try.
You may try to step into mfsStart() and see where exactly if fails, I suppose it is where it tries to read the header back which would hint to an EFL problem.
Return to “Bug Reports”
Users browsing this forum: No registered users and 66 guests
