hal_sdc misuses SET_RELATIVE_ADDR cmd for eMMC Topic is solved
Mbroek635
Postby Mbroek635 » Thu Nov 24, 2022 5:02 pm
In sdc_hal.c the relative address is requested from an sd card:
https://github.com/ChibiOS/ChibiOS/blob ... sdc.c#L674
MMCSD_CMD_SEND_RELATIVE_ADDR tranalates to CMD3.
This is correct according to the SD SDIO specification.
However this is not correct for eMMC devices.
eMMC devices use CMD3 as SET_RELATIVE_ADDR.
source:
https://linux.codingbelief.com/zh/stora ... mands.html
I'd suggest the following patch:
diff --git a/os/hal/include/hal_mmcsd.h b/os/hal/include/hal_mmcsd.h
index ab4977557..1294ded49 100644
--- a/os/hal/include/hal_mmcsd.h
+++ b/os/hal/include/hal_mmcsd.h
@@ -71,6 +71,7 @@
 #define MMCSD_CMD_INIT                  1U
 #define MMCSD_CMD_ALL_SEND_CID          2U
 #define MMCSD_CMD_SEND_RELATIVE_ADDR    3U
+#define MMCSD_CMD_SET_RELATIVE_ADDR     MMCSD_CMD_SEND_RELATIVE_ADDR
 #define MMCSD_CMD_SET_BUS_WIDTH         6U
 #define MMCSD_CMD_SWITCH                MMCSD_CMD_SET_BUS_WIDTH
 #define MMCSD_CMD_SEL_DESEL_CARD        7U
diff --git a/os/hal/src/hal_sdc.c b/os/hal/src/hal_sdc.c
index d10010389..acfb8af3a 100644
--- a/os/hal/src/hal_sdc.c
+++ b/os/hal/src/hal_sdc.c
@@ -654,7 +654,7 @@ bool sdcConnect(SDCDriver *sdcp) {
   /* Perform specific initialization procedure.*/
-  if ((sdcp->cardmode &  SDC_MODE_CARDTYPE_MASK) == SDC_MODE_CARDTYPE_MMC) {
+  if ((sdcp->cardmode & SDC_MODE_CARDTYPE_MASK) == SDC_MODE_CARDTYPE_MMC) {
     if (HAL_FAILED == mmc_init(sdcp)) {
       goto failed;
@@ -670,10 +670,19 @@ bool sdcConnect(SDCDriver *sdcp) {
     goto failed;
-  /* Asks for the RCA.*/
-  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SEND_RELATIVE_ADDR,
-                                 0, &sdcp->rca)) {
-    goto failed;
+    /* Set the RCA.*/
+    sdcp->rca = 0;
+    if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SET_RELATIVE_ADDR,
+                                  sdcp->rca, resp)) {
+      goto failed;
+  } else {
+    /* Asks for the RCA.*/
+    if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SEND_RELATIVE_ADDR,
+                                  0, &sdcp->rca)) {
+      goto failed;
   /* Reads CSD.*/
Make of this what you will. This does not fully support relative addresses.
I'm on ChibiOS stable 21.11.x.
Using an stm32l496.
Re: hal_sdc misuses SET_RELATIVE_ADDR cmd for eMMC
Postby Giovanni » Fri Dec 09, 2022 11:14 am
I added that definition, thanks.
Return to “Bug Reports”
Users browsing this forum: No registered users and 63 guests
