[HELP] STM32H750 USB HS ULPI Support, Topic is solved
alex31
Has thanked: 50 times
Been thanked: 81 times
Re: [HELP] STM32H750 USB HS ULPI Support,
Postby alex31 » Wed Apr 03, 2024 1:43 pm
Welcome to the high speed usb issues club :-)
I am also having unresolved problem with a custom H743 board trying to use ULPI at HS speed (480 Mb/s) for MSD (USB storage).
For now, I am able to have reliable OTG2 + ULPI + MSD, but ultimately, after host <-> device handshake, speed is reverted to FS, and I can confirm using dd that I am limited to 12Mb/s not 480Mb/s.
When running under debugger, I can see that in
usb_lld_serve_interrupt
, after enumeration,
((otgp->DSTS & DSTS_ENUMSPD_MASK) == DSTS_ENUMSPD_HS_480)
evaluate to false, reverting to FS.
I am still investigating to determine if it's a hardware or software issue.
Alexandre
Has thanked: 1132 times
Been thanked: 944 times
Postby Giovanni » Wed Apr 03, 2024 7:12 pm
It could be a SW issue, ULPI has not extensively tested.
alex31
Postby alex31 » Wed Apr 03, 2024 11:08 pm
Found a DISCOVERY_746 in a drawer, it uses the same ULPI component as our custom card.
Flash ST Application from F7Cube that does MSD over USB HS, and got the very same symptoms : works at 12Mb/s speed limit.
Will use ST forum tomorrow to seek for help :-)
A.
twarge
Been thanked: 2 times
Postby twarge » Thu Apr 04, 2024 3:11 am
I had previously asserted that we had an ULPI interface working on H743, but I have to say that we didn't verify that we got the high speed; it's possible that we also got the standard 12 Mbit/s.
alex31
Postby alex31 » Tue Apr 09, 2024 6:54 am
Good news for ChibiOS : I have ported USB_MSD example from contrib to the discovery F746 and it works perfectly in USB HS.
So the problem is probably a hardware problem with our H743 design, perhaps due to the use of USBC connector instead of micro usb ?
@twarge, did you use mini/micro usb or usbC on your design ? If at a time you can verify that your H743 design connect at high speed, that would be a good indication for us.
Alexandre
alex31
Postby alex31 » Wed Apr 10, 2024 6:09 pm
problem solved for my case. It's an issue with recent ULPI PHY that implement LPM. With old families of PHY like microchip 332x that did not implement LPM, handshake works, but with more recent families like microchip 334x, an additional delay is needed in the handshake.
This is explained in ST forum on page 3 of this thread :
st forum on ULPI HS issues
This is also found in an errata section in the microchip 3340 PHY.
additional delay can be inserted using setting XCVRDLY bit in the DCFG register when using that kind of PHY.
I propose a patch which does the job when BOARD_OTG2_ULPI_ACTIVATE_CHIRP_DELAY is defined.
Alexandre
ulpiDelayMask.diff.zip
patch over 21.11.4
(924 Bytes) Downloaded 203 times
microchip errata
Postby Giovanni » Wed Apr 10, 2024 7:29 pm
Great thanks, moving this topic in "bug reports" so it is not lost.
Postby Giovanni » Mon Oct 14, 2024 9:23 am
Proposed patch applied to repository.
Return to “Bug Reports”
Users browsing this forum: No registered users and 51 guests
