Inconsistency/clash in using MPU regions Topic is solved
steved
Has thanked: 12 times
Been thanked: 135 times
Postby steved » Wed Mar 29, 2023 3:05 pm
For the 32H7, STM32_NOCACHE_MPU_REGION and STM32_NOCACHE_ENABLE are defined.
The 32F7 defines STM32_SRAM2_NOCACHE, and hard codes MPU_REGION_7 in hal_lld.c
.....but in chcore.h you have:
#define PORT_USE_GUARD_MPU_REGION       MPU_REGION_7
As a minimum, I suggest that STM32_NOCACHE_MPU_REGION should be supported for the F7, to avoid the clash of assignments
Re: Inconsistency/clash in using MPU regions
Postby Giovanni » Tue Apr 11, 2023 12:49 pm
Yes, it should be similar to the H7 solution, will do this way.
Postby Giovanni » Thu Apr 13, 2023 6:25 pm
Committed the change.
Return to “Bug Reports”
Users browsing this forum: No registered users and 46 guests
