STM32F413xx missed as possible enumeration in stm32f4xx_board.xsd Topic is solved
Notice that while editing board.chcfg in XML editor, element <subtype>STM32F413xx</subtype> marked with warning. The cause of this warning is absent of STM32F413xx enumeration in stm32f4xx_board.xsd.
Re: STM32F413xx missed as possible enumeration in stm32f4xx_board.xsd
Also, it will be great to release board_files_path restrictions in tools/ftl/schema/common/config_settings.xsd file to have the possibility to pass their path with makefile variable references.
Currently, I get the following warning:
cvc-pattern-valid: Value '$(BOARDS_DIR)' is not facet-valid with respect to pattern '[\w\d_/.]+' for type '#AnonType_board_files_pathConfigurationSettingsType'.xml(cvc-pattern-valid)
cvc-type.3.1.3: The value '$(BOARDS_DIR)' of element 'board_files_path' is not valid.xml(cvc-type.3.1.3)
Added F413, the other change is not straightforward.
