Typo in hal_block_io.xml Topic is solved
Dron_Gus
Postby Dron_Gus » Sat Dec 16, 2023 1:49 pm
diff --git a/os/xhal/codegen/hal_block_io.xml b/os/xhal/codegen/hal_block_io.xml
index 010995f2e..256953561 100644
--- a/os/xhal/codegen/hal_block_io.xml
+++ b/os/xhal/codegen/hal_block_io.xml
@@ -55,7 +55,7 @@
             <retval value="true">If the operation failed.</retval>
             <api />
           </method>
-          <method name="blkDisonnect" shortname="disconnect"
+          <method name="blkDisconnect" shortname="disconnect"
             ctype="bool">
             <brief>Disconnection from the block device.</brief>
             <return>The operation status.</return>
Hope this is enough to fix autogenerated hal_block_io.h
0001-typo-blkDisonnect-blkDisconnect.zip
(723 Bytes) Downloaded 92 times
Re: Typo in hal_block_io.xml
Postby Giovanni » Sun Dec 17, 2023 11:58 am
Fixed in thunk, thanks.
Return to “Bug Reports”
