fifoObject internal bug Topic is solved
alex31
Has thanked: 38 times
Been thanked: 62 times
Postby alex31 » Fri Dec 22, 2023 5:39 pm
using chibios 21.11.x with lasts updates
I have occurrence of error using fifoObject api when I stress it a bit
where internal assert fails in chGuardedPoolAllocI (called by chFifoTakeObjectI) :
  chDbgAssert(chSemGetCounterI(&gmp->sem) >= (cnt_t)0, // ** gdb show that gmp->sem = -1 **
                "semaphore out of sync");
To trigger the bug, I have
° a sender thread that does regular but slow pace take(TIME_INFINITE)
° ISR that does takeI->sendI at high rate (so most of the time takeI return null so no sendI are made)
° a receiver thread that receive(TIME_INFINITE) in infinite loop, but is speed limited by I/O
it seems that this condition trigger the bug :
°the sender thread is blocked on the take(TIME_INFINITE)
°the receiver thread return an object
°at the same time and ISR does a takeI
problem occurs in a C++ library, but I can write a small C program that exhibit behavior if it helps.
I have checked that it's not a stack overflow.
Alexandre
Re: fifoObject internal bug
Postby Giovanni » Fri Dec 22, 2023 9:13 pm
What is the priority of the IRQ?
alex31
Postby alex31 » Fri Dec 22, 2023 11:42 pm
That's a good question, I use GPTD5 and
#define STM32_IRQ_TIM5_PRIORITY             7
So it seems that it's more that 2 so it should be OK
A.
Postby Giovanni » Sat Dec 23, 2023 7:42 am
Could you try the following?
static inline void *chGuardedPoolAllocI(guarded_memory_pool_t *gmp) {
  void *p;
  if (chSemGetCounterI(&gmp->sem) > (cnt_t)0) {
    chSemFastWaitI(&gmp->sem);
    p = chPoolAllocI(&gmp->pool);
  else {
    p = NULL;
  return p;
alex31
Postby alex31 » Sat Dec 23, 2023 9:11 am
beautiful, works flawlessly.
You have resolved a race condition with a patch that also make the code shorter, that's fine !
Alexandre
Postby Giovanni » Sat Dec 23, 2023 12:37 pm
Thanks, I will commit this to all branches.
Postby Giovanni » Tue Dec 26, 2023 12:50 pm
Fixed as 1277.
Return to “Bug Reports”
