sdc erase handling of sdhc sdxc card Topic is solved
alex31
Has thanked: 47 times
Been thanked: 80 times
Postby alex31 » Sun Jan 28, 2024 10:34 am
sdcErase fails for high capacity SD card.
from https://chlazza.nfshost.com/sdcardinfo.html, note 10 => 10. SDSC Card (CCS=0) uses byte unit address and SDHC and SDXC Cards (CCS=1) use block unit address (512 bytes unit).
So the test in sdcErase seems inverted
tested with if ((sdcp->cardmode & SDC_MODE_HIGH_CAPACITY) == 0U)
and it works !
when the following patch is applied, sdcErase works for sdhc card.
diff --git a/os/hal/src/hal_sdc.c b/os/hal/src/hal_sdc.c
index e2c6452f7..7160f255a 100644
--- a/os/hal/src/hal_sdc.c
+++ b/os/hal/src/hal_sdc.c
@@ -967,7 +967,7 @@ bool sdcErase(SDCDriver *sdcp, uint32_t startblk, uint32_t endblk) {
   sdcp->state = BLK_WRITING;
   /* Handling command differences between HC and normal cards.*/
-  if ((sdcp->cardmode & SDC_MODE_HIGH_CAPACITY) != 0U) {
+  if ((sdcp->cardmode & SDC_MODE_HIGH_CAPACITY) == 0U) {
     startblk *= MMCSD_BLOCK_SIZE;
     endblk *= MMCSD_BLOCK_SIZE;
Alexandre
Has thanked: 1112 times
Been thanked: 937 times
Re: sdc erase handling of sdhc sdxc card
Postby Giovanni » Mon Oct 14, 2024 9:08 am
Fixed in repository.
Return to “Bug Reports”
Users browsing this forum: Bing [Bot] and 6 guests
