in os/hal/ports/STM32/STM32H7xx/platform.mk, as well as os/hal/ports/STM32/STM32H7xx/platform_type2.mk, there is RTCv2 selected. the STM32H7A3, STM32H7B3 and STM32H7B0 (Q and no-Q variants) have something, that is much more similar to RTCv3, it seems.
should those variations of the STM32H7 use a possibly new os/hal/ports/STM32/STM32H7xx/platform_type3.mk?
at the moment (r16597), setting HAL_USE_RTC to TRUE fails for me. also with RTCv3, as some defines and a macro is/are missing:
Compiling hal_rtc_lld.c
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c: In function 'rtc_lld_serve_interrupt':
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:273:3: error: implicit declaration of function 'STM32_RTC_CLEAR_ALL_EXTI'; did you mean 'STM32_RTC_ALARM_EXTI'? [-Wimplicit-function-declaration]
273 | STM32_RTC_CLEAR_ALL_EXTI();
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c: In function 'rtc_lld_init':
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:437:44: error: 'STM32_RTC_CR_MASK' undeclared (first use in this function); did you mean 'STM32_RTCSEL_MASK'?
437 | RTCD1.rtc->CR = (STM32_RTC_CR_INIT & STM32_RTC_CR_MASK) | RTC_CR_BYPSHAD;
| STM32_RTCSEL_MASK
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:437:44: note: each undeclared identifier is reported only once for each function it appears in
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:450:47: error: 'STM32_TAMP_CR1_MASK' undeclared (first use in this function); did you mean 'STM32_TAMP_CR1_INIT'?
450 | RTCD1.tamp->CR1 |= (STM32_TAMP_CR1_INIT & STM32_TAMP_CR1_MASK);
| STM32_TAMP_CR1_INIT
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:451:47: error: 'STM32_TAMP_CR2_MASK' undeclared (first use in this function); did you mean 'STM32_TIM_CR2_MMS2'?
451 | RTCD1.tamp->CR2 |= (STM32_TAMP_CR2_INIT & STM32_TAMP_CR2_MASK);
| STM32_TIM_CR2_MMS2
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:452:49: error: 'STM32_TAMP_FLTCR_MASK' undeclared (first use in this function); did you mean 'STM32_TAMP_FLTCR_INIT'?
452 | RTCD1.tamp->FLTCR |= (STM32_TAMP_FLTCR_INIT & STM32_TAMP_FLTCR_MASK);
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:453:47: error: 'STM32_TAMP_IER_MASK' undeclared (first use in this function); did you mean 'STM32_MDMA_ISR_MASK'?
453 | RTCD1.tamp->IER |= (STM32_TAMP_IER_INIT & STM32_TAMP_IER_MASK);
| STM32_MDMA_ISR_MASK
os/hal/ports/STM32/LLD/RTCv3/hal_rtc_lld.c:459:3: error: implicit declaration of function 'STM32_RTC_ENABLE_ALL_EXTI'; did you mean 'STM32_RTC_ALARM_EXTI'? [-Wimplicit-function-declaration]
459 | STM32_RTC_ENABLE_ALL_EXTI();
make[1]: *** [os/common/startup/ARMCMx/compilers/GCC/mk/rules.mk:194: builds/STM32H7A3II/obj/hal_rtc_lld.o] Error 1
make[1]: Leaving directory 'src'
make: *** [Makefile:225: builds/STM32H7A3II/STM32H7A3II.elf] Error 2
further, some code in os/hal/ports/STM32/STM32H7xx/hal_lld.c in function init_bkp_domain() may need to be adjusted, as it resets the backup domain (which includes the wiping RTC backup registers), when HAL_USE_RTC is set to FALSE. maybe wrapping
#if HAL_USE_RTC
#endif /* HAL_USE_RTC */
around
/* Reset BKP domain if different clock source selected.*/
if ((RCC->BDCR & STM32_RTCSEL_MASK) != STM32_RTCSEL) {
/* Backup domain reset.*/
RCC->BDCR = RCC_BDCR_BDRST;
RCC->BDCR = 0;
is sufficient …
