fdcanV2 wrong assertion in the filtering code Topic is solved
alex31
Has thanked: 54 times
Been thanked: 83 times
Postby alex31 » Wed Nov 27, 2024 4:22 pm
First, I want to thanks Edoardo for the hdcanv1/v2 refactor, and filtering integration.
I will in the future submit some patches driven by real usager in flying machine.
For now just a simple bug, fdcanv2 will wrongly assert when using filtering on CAND1 :
void can_lld_set_filters(CANDriver *canp, uint8_t num, const CANFilter *cfp) {
  uint8_t i;
  uint8_t num_std_filter = 0;
  uint8_t num_ext_filter = 0;
  uint32_t can_offset_instance = 0;
  #if STM32_CAN_USE_FDCAN1
  if (&CAND1 == canp) {
    can_offset_instance = CAN1_OFFSET_INSTANCE;
  #if STM32_CAN_USE_FDCAN2
  if (&CAND2 == canp) {
    can_offset_instance = CAN2_OFFSET_INSTANCE;
  #if STM32_CAN_USE_FDCAN3
  if (&CAND3 == canp) {
    can_offset_instance = CAN3_OFFSET_INSTANCE;
  osalDbgAssert(can_offset_instance != 0, "CAN offset instance failed");
when using CAND1, CAN1_OFFSET_INSTANCE is 0, so the assert will always fire.
Alexandre
Edoardo1982
Has thanked: 10 times
Been thanked: 20 times
Re: fdcanV2 wrong assertion in the filtering code
Postby Edoardo1982 » Wed Dec 04, 2024 7:46 pm
alex31 wrote:Hello,
  uint8_t i;
Alexandre
Hi Alex,
I believe the code you posted is incorrect, and I’m not sure where it was taken from because it doesn’t seem like something I wrote, there’s no trace of it in the trunk.
In any case, I encourage you to check the latest changes I made to the FDCANv1 and v2 drivers into the trunk.
Edoardo
alex31
Postby alex31 » Wed Dec 04, 2024 9:49 pm
My bad, I checked in trunk and there is no trace of this code,
Many apologizes for this.
Alexandre
Return to “Bug Reports”
