- adcConvert (GroupA) = [ ChannelA0, ChannelA1 ]
- adcConvert (GroupB) = [ ChannelA0, ChannelB0 ] (Missing ChannelB1, B0 in B1's slot)
The issue occurs for any number of channels in either group, tested with 1v1, 2v1, 16v9, just with different timing required. I have a chSysPolledDelayX in between the converts. I can go from a 0.03% failure rate to 99.9% failure rate by changing the polled delay from 61 to a 62 at 168 MHz.
I am able to resolve this in 2 ways by modifying ADCv2. The first is removing ADC_CR2_CONT from CR2 in adc_lld_start_conversion (breaks the depth parameter when != 1). The second is clearing CR2_ADON in adc_lld_stop_conversion, basically undoing the #822 bug fix (adcp->adc->CR2 = 0; adcp->adc->CR2 = ADC_CR2_ADON;).
I will also note the #822 bug fix in adc_lld_stop_conversion seems incomplete as the first CR2 line preserves the injected bits, but the second CR2 line clears them anyway. So injected channels would still be disabled after a completed non-circular adcConvert. SWSTART is also cleared by hardware on start of conversion, so the first CR2 write doesn't really do anything.
The other thing I noticed is that, once fixed, the frequency of execution of the adcConverts slows down. Using the second fix, it goes from 33798 Hz to 30543 Hz. This and some logic analyzer palToggleLines in ISRs indicate that there is an early DMA RX ISR occurring. In the attached image, the red timing marks indicate a failure with 13.14 us from DMA int to DMA int, where the green one is the standard / correct 16.34 us.
We are running with the second fix for now as we don't use injected channels.
I verified this on an STM32F4 Discovery board, 168 MHz, GNU Arm Embedded Toolchain 10.3-2021.10, -O2, ChibiOS 21.11.2.
For the following code, PA0 is tied to ground for sampling and VREFINT is also sampled for 2 significantly different values. The tunable delay is nDelayAfterA. The comments have some values that worked for me. Interestingly, depth of 1 or 2 doesn't require changing the delay.
The once a second serial printout seems necessary for probably timing reasons. G_Line_Adc_Int and G_Line_Dma_Int are configured and ready to be injected with palToggleLine in the DMA and ADC interrupts. I can provide additional information (logic analyzer captures, etc) if you need.
Patrick
#include "ch.h"
#include "chprintf.h"
static BaseSequentialStream* const G_Debug = (BaseSequentialStream*) &SD2;
// Grounded externally.
static const ioline_t G_Line_InputPin = PAL_LINE (GPIOA, 0);
static const ioline_t G_Line_ConvertA = PAL_LINE (GPIOC, 1);
static const ioline_t G_Line_ConvertB = PAL_LINE (GPIOC, 2);
static const ioline_t G_Line_FailA = PAL_LINE (GPIOB, 0);
static const ioline_t G_Line_FailB = PAL_LINE (GPIOB, 1);
ioline_t G_Line_Adc_Int = PAL_LINE (GPIOE, 7);
ioline_t G_Line_Dma_Int = PAL_LINE (GPIOE, 8);
// ADC Configs
static const ADCConfig G_AdcConfig = {};
static const ADCConversionGroup G_GroupA = {
.circular = false,
.num_channels = 2,
.end_cb = NULL,
.error_cb = NULL,
.cr1 = 0,
.cr2 = ADC_CR2_SWSTART,
.smpr1 = 0,
.smpr2 = ADC_SMPR2_SMP_AN0 (ADC_SAMPLE_56),
.htr = 0,
.ltr = 0,
.sqr1 = 0,
.sqr2 = 0,
.sqr3 = ADC_SQR3_SQ1_N (ADC_CHANNEL_IN0) | ADC_SQR3_SQ2_N (ADC_CHANNEL_IN0)
static const ADCConversionGroup G_GroupB = {
.circular = false,
.num_channels = 2,
.end_cb = NULL,
.error_cb = NULL,
.cr1 = 0,
.smpr1 = ADC_SMPR1_SMP_VREF (ADC_SAMPLE_56),
.smpr2 = 0,
.htr = 0,
.ltr = 0,
.sqr1 = 0,
.sqr2 = 0,
.sqr3 = ADC_SQR3_SQ1_N (ADC_CHANNEL_VREFINT) | ADC_SQR3_SQ2_N (ADC_CHANNEL_VREFINT)
static THD_WORKING_AREA (waThreadHeartbeat, 128);
static THD_FUNCTION (ThreadHeartbeat, arg)
(void) arg;
chRegSetThreadName ("blinker");
while (true)
palSetLine (LINE_LED_BLUE);
chThdSleepMilliseconds (500);
palClearLine (LINE_LED_BLUE);
static void debugPrintf (const char* sFmt, ...)
va_list ap;
va_start(ap, sFmt);
chvprintf(G_Debug, sFmt, ap);
va_end(ap);
int main ()
// Initialize ChibiOS.
halInit ();
chSysInit ();
// Initialize the debug serial output. Print a startup message with the revision.
sdStart (&SD2, NULL);
debugPrintf ("\r\n\r\nLaunching %s\r\n", "AdcDiag");
// Start the heartbeat thread.
chThdCreateStatic (waThreadHeartbeat, sizeof (waThreadHeartbeat), NORMALPRIO, ThreadHeartbeat,
NULL);
// Serial
palSetPadMode (GPIOA, 2, PAL_MODE_ALTERNATE(7));
// ADC Grounded externally.
palSetLineMode (G_Line_InputPin, PAL_MODE_INPUT_ANALOG);
// Logic analyzer outputs
palSetLineMode (G_Line_ConvertA, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST);
palSetLineMode (G_Line_ConvertB, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST);
palSetLineMode (G_Line_FailA, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST);
palSetLineMode (G_Line_FailB, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST);
palSetLineMode (G_Line_Adc_Int, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST);
palSetLineMode (G_Line_Dma_Int, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST);
// ADC setup
adcStart (&ADCD1, &G_AdcConfig);
adcSTM32EnableTSVREFE ();
rtcnt_t nTimeBeforeB = 0;
systime_t nLast = chVTGetSystemTimeX ();
int n = 0;
int nAFail = 0;
int nBFail = 0;
adcsample_t a [4];
adcsample_t b [4];
// 0: 9 B failures / s
// 44: No failures
// 61: 10 B failures / s
// 62: 33k B failures / s
// 200: 3 A failures / s
volatile rtcnt_t nDelayAfterA = 62;
while (true)
rtcnt_t nLastTimeBeforeB = nTimeBeforeB;
rtcnt_t nTimeBeforeA = chSysGetRealtimeCounterX ();
palToggleLine (G_Line_ConvertA);
adcConvert (&ADCD1, &G_GroupA, a, 1);
chSysPolledDelayX (nDelayAfterA);
nTimeBeforeB = chSysGetRealtimeCounterX ();
palToggleLine (G_Line_ConvertB);
adcConvert (&ADCD1, &G_GroupB, b, 1);
// Threshold checks
// A is grounded (PA0)
bool bAFailed = a [0] > 100;
// B is VREFINT, significantly non-zero.
bool bBFailed = b [0] < 1400 || b [0] > 1800;
if (bAFailed)
nAFail++;
palToggleLine (G_Line_FailA);
// debugPrintf ("A: %4d, %4d\r\n", a [0], a [1]);
if (bBFailed)
nBFail++;
palToggleLine (G_Line_FailB);
// debugPrintf ("B: %4d, %4d\r\n", b [0], b [1]);
// Print results once a second
n++;
systime_t nNow = chVTGetSystemTimeX ();
if (nNow - nLast > TIME_MS2I(1000))
nLast = nNow;
debugPrintf ("nDelayAfterA: %d, Hz: %d, A to B Delay = %d, B to A Delay = %d, A Fail = %d, B Fail = %d\r\n",
nDelayAfterA, n, nTimeBeforeB - nTimeBeforeA,
nTimeBeforeA - nLastTimeBeforeB, nAFail, nBFail);
n = 0;
nAFail = 0;
nBFail = 0;
