ease the use of G++ as LD when needed
alex31
Has thanked: 36 times
Been thanked: 56 times
Postby alex31 » Fri Apr 29, 2022 9:15 am
Before 21.11, the compiler settings where done in the top level makefile.
Now, it's done in arm-none-eabi.mk sub makefile included at the end of the top level makefile.
Some project need to link with G++ (example : when there is global objects with virtual constructor / destructor)
I propose that, at least for LD, the setting be done only if LD is empty, or left to the non arm-none-eabi one :
ifeq (,$(findstring $(TRGT),$(LD)))
LD   = $(TRGT)gcc
endif
So far, if one puts his own definition in the compiler option section of the makefile (which is before the include of arm-none-eabi.mk), his own LD definition will not be overwritten.
Alexandre
Users browsing this forum: No registered users and 5 guests
