Hi Did this ever get implemented ?
There was alot of talk about it pre 3.0
SPI Slave Driver
Re: SPI Slave Driver
Giovanni wrote:Not yet, I have no a clear idea of how a SSPI API should look like.
I'm trying to hack together something using the SPIv1 (on F103) setting up should not be an issue as just needed to let the lower level driver know its either Master or Slave, do this by adding another variable to the SPIConfig struct.
The issue will be around what does one do to wait for incoming data from SPI master ?
Do you have any ideas ? Would be nice a callback interface, so every reception from the SPI you get a callback where you can process the recieved data and then send back response message.
The problem is when you have a scenario when the incoming data is not of fixed size (you can hack the existing driver for that). Imagine having to implement an SD/MMC card in SPI mode, a driver should be flexible enough to allow something like that.
If the data is fixed length, then will the current driver able able to receive data and send data when set in slave mode ?
if so what is the best method / API calls i.e
spiExchange(&SPID1, 1, txbuf, rxbuf); /* Atomic transfer operations. */
or
spiReceive
spiSend
or
spiReceive
spiSend
I know somebody did it, I have no details.
I think you can use any of those functions, depending on what you need to do.
Giovanni wrote:I know somebody did it, I have no details.
but i believe they used a raw interface not the dma one as used by the current driver.
So not sure if the dma will cause me issues
Tabulous wrote:Giovanni wrote:I know somebody did it, I have no details.
It does: you need to know the transfer size beforehand.
