Makefile verbose mode checks
meatball
Has thanked: 9 times
Been thanked: 2 times
Postby meatball » Sat Jun 27, 2020 5:27 pm
I have a small suggestion for the makefiles that use the USE_VERBOSE_COMPILE flag from the project makefile.
Instead of explicitly checking the flag for each target rule like this:
$(TCOBJS) : $(OBJDIR)/%.o : %.c $(MAKEFILE_LIST)
ifeq ($(USE_VERBOSE_COMPILE),yes)
   @echo
   $(CC) -c $(CFLAGS) -I. $(IINCDIR) $< -o $@
else
   @echo Compiling $(<F)
   @$(CC) -c $(CFLAGS) -I. $(IINCDIR) $< -o $@
endif
We can just assign the output suppress character (@) to a variable at the top of the file, and use it each time:
# Verbose flag
Q=
NL="\n"Compiling
else
Q=@
NL=
endif
This simplifies the rules to something like this:
   $(V)echo $(NL) $(<F)
   $(V)$(CC) -c $(CFLAGS) -I. $(IINCDIR) $< -o $@
Maybe there is a good reason for keeping the if/else checks in place for every rule, but I think this is cleaner to read through. It's quite similar to a C preprocessor #define, which can really clean up and abstract away repetitive settings.
Is there a good reason to keep the explicit if/else checks in place for each target rule?
Thanks!
Has thanked: 1074 times
Been thanked: 921 times
Re: Makefile verbose mode checks
Postby Giovanni » Sat Jun 27, 2020 6:41 pm
If I have to mention a reason then it is readability, in the first case the information is "local", you understand what the code does without having to find definitions for Q and NL in some other place. USE_VERBOSE_COMPILE is pretty self-describing.
