Add support for TIM15-17 to hal_st_lld
FXCoder
Has thanked: 180 times
Been thanked: 130 times
Postby FXCoder » Mon Jul 06, 2020 2:21 pm
Hi.
Needed to use TIM16 for ST_TIM so added 15-17 to hal_st_lld.
Tested on L4+ only.
Bob
diff --git a/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.c b/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.c
index 22a513c..4f5a231 100644
--- a/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.c
+++ b/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.c
@@ -282,6 +282,74 @@
 #define ST_ENABLE_STOP()                    DBGMCU->APB1FZ |= DBGMCU_APB1_FZ_DBG_TIM14_STOP
+#elif STM32_ST_USE_TIMER == 15
+#if !STM32_HAS_TIM15
+#error "TIM15 not present in the selected device"
+#endif
+#if (OSAL_ST_RESOLUTION == 32) && !STM32_TIM15_IS_32BITS
+#error "TIM15 is not a 32bits timer"
+#endif
+#define ST_HANDLER                          STM32_TIM15_HANDLER
+#define ST_NUMBER                           STM32_TIM15_NUMBER
+#define ST_CLOCK_SRC                        STM32_TIMCLK2
+#define ST_ENABLE_CLOCK()                   rccEnableTIM15(true)
+#if defined(STM32L4XX) || defined(STM32L4XXP) || defined(STM32G4XX)
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ |= DBGMCU_APB2FZ_DBG_TIM15_STOP
+#elif defined(STM32H7XX)
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ1 |= DBGMCU_APB2FZ1_DBG_TIM15
+#else
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ |= DBGMCU_APB2_FZ_DBG_TIM15_STOP
+#endif
+#elif STM32_ST_USE_TIMER == 16
+#if !STM32_HAS_TIM16
+#error "TIM16 not present in the selected device"
+#endif
+#if (OSAL_ST_RESOLUTION == 32) && !STM32_TIM16_IS_32BITS
+#error "TIM16 is not a 32bits timer"
+#endif
+#define ST_HANDLER                          STM32_TIM16_HANDLER
+#define ST_NUMBER                           STM32_TIM16_NUMBER
+#define ST_ENABLE_CLOCK()                   rccEnableTIM16(true)
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ |= DBGMCU_APB2FZ_DBG_TIM16_STOP
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ1 |= DBGMCU_APB2FZ1_DBG_TIM16
+#else
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ |= DBGMCU_APB2_FZ_DBG_TIM16_STOP
+#endif
+#elif STM32_ST_USE_TIMER == 17
+#if !STM32_HAS_TIM17
+#error "TIM17 not present in the selected device"
+#endif
+#if (OSAL_ST_RESOLUTION == 32) && !STM32_TIM17_IS_32BITS
+#error "TIM17 is not a 32bits timer"
+#endif
+#define ST_HANDLER                          STM32_TIM17_HANDLER
+#define ST_NUMBER                           STM32_TIM17_NUMBER
+#define ST_ENABLE_CLOCK()                   rccEnableTIM17(true)
+#if defined(STM32F1XX)
+#define ST_ENABLE_STOP()                    DBGMCU->CR |= DBGMCU_CR_DBG_TIM17_STOP
+#elif defined(STM32L4XX) || defined(STM32L4XXP) || defined(STM32G4XX)
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ |= DBGMCU_APB2FZ_DBG_TIM17_STOP
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ1 |= DBGMCU_APB2FZ1_DBG_TIM17
+#else
+#define ST_ENABLE_STOP()                    DBGMCU->APB2FZ |= DBGMCU_APB2_FZ_DBG_TIM17_STOP
+#endif
 #elif STM32_ST_USE_TIMER == 21
 #if !STM32_HAS_TIM21
diff --git a/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.h b/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.h
index 20d6426..c88c420 100644
--- a/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.h
+++ b/software/tracker/ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.h
@@ -117,6 +117,17 @@
 #define STM32_HAS_TIM14                      FALSE
+#if !defined(STM32_HAS_TIM15)
+#define STM32_HAS_TIM15                      FALSE
+#endif
+#if !defined(STM32_HAS_TIM16)
+#define STM32_HAS_TIM16                      FALSE
+#endif
+#if !defined(STM32_HAS_TIM17)
+#define STM32_HAS_TIM17                      FALSE
+#endif
 #if !defined(STM32_HAS_TIM21)
 #define STM32_HAS_TIM21                     FALSE
@@ -153,6 +164,9 @@
 #define STM32_ST_USE_TIM12                  FALSE
 #define STM32_ST_USE_TIM13                  FALSE
 #define STM32_ST_USE_TIM14                  FALSE
+#define STM32_ST_USE_TIM15                  FALSE
+#define STM32_ST_USE_TIM16                  FALSE
+#define STM32_ST_USE_TIM17                  FALSE
 #define STM32_ST_USE_TIM21                  FALSE
 #define STM32_ST_USE_TIM22                  FALSE
@@ -181,6 +195,9 @@
@@ -209,6 +226,9 @@
@@ -237,6 +257,9 @@
@@ -265,6 +288,9 @@
@@ -293,6 +319,9 @@
@@ -321,6 +350,9 @@
@@ -349,6 +381,9 @@
 #define STM32_ST_USE_TIM12                  TRUE
@@ -377,6 +412,9 @@
 #define STM32_ST_USE_TIM13                  TRUE
@@ -405,6 +443,102 @@
 #define STM32_ST_USE_TIM14                  TRUE
+#define STM32_ST_USE_TIM21                  FALSE
+#define STM32_ST_USE_TIM22                  FALSE
+#if defined(STM32_TIM15_IS_USED)
+#error "ST requires TIM15 but the timer is already used"
+#else
+#define STM32_TIM15_IS_USED
+#endif
+#if defined(STM32_TIM15_SUPPRESS_ISR)
+#define STM32_SYSTICK_SUPPRESS_ISR
+#endif
+#define STM32_ST_TIM                        STM32_TIM15
+#define ST_LLD_NUM_ALARMS                   STM32_TIM15_CHANNELS
+#define STM32_ST_USE_SYSTICK                FALSE
+#define STM32_ST_USE_TIM2                   FALSE
+#define STM32_ST_USE_TIM3                   FALSE
+#define STM32_ST_USE_TIM4                   FALSE
+#define STM32_ST_USE_TIM5                   FALSE
+#define STM32_ST_USE_TIM9                   FALSE
+#define STM32_ST_USE_TIM10                  FALSE
+#define STM32_ST_USE_TIM11                  FALSE
+#define STM32_ST_USE_TIM12                  FALSE
+#define STM32_ST_USE_TIM13                  FALSE
+#define STM32_ST_USE_TIM14                  FALSE
+#define STM32_ST_USE_TIM15                  TRUE
+#if defined(STM32_TIM16_IS_USED)
+#error "ST requires TIM16 but the timer is already used"
+#else
+#define STM32_TIM16_IS_USED
+#endif
+#if defined(STM32_TIM16_SUPPRESS_ISR)
+#endif
+#define STM32_ST_TIM                        STM32_TIM16
+#define ST_LLD_NUM_ALARMS                   STM32_TIM16_CHANNELS
+#define STM32_ST_USE_TIM16                  TRUE
+#if defined(STM32_TIM17_IS_USED)
+#error "ST requires TIM17 but the timer is already used"
+#else
+#define STM32_TIM17_IS_USED
+#endif
+#if defined(STM32_TIM17_SUPPRESS_ISR)
+#endif
+#define STM32_ST_TIM                        STM32_TIM17
+#define ST_LLD_NUM_ALARMS                   STM32_TIM17_CHANNELS
+#define STM32_ST_USE_TIM17                  TRUE
@@ -433,6 +567,9 @@
 #define STM32_ST_USE_TIM21                  TRUE
@@ -461,6 +598,9 @@
 #define STM32_ST_USE_TIM22                  TRUE
@@ -491,6 +631,9 @@
@@ -507,6 +650,9 @@
FXCoder
Re: Add support for TIM15-17 to hal_st_lld
Postby FXCoder » Thu Dec 10, 2020 12:30 pm
Updated in trunk.
Users browsing this forum: No registered users and 30 guests
