lwip timer and core locking
vysocan
Has thanked: 3 times
Postby vysocan » Thu Jun 17, 2021 2:19 pm
for past year I'm using liwp in my application running on STM32F4xx. I have a few services running like dhcp, httpd, sntp, all running fine only until I added mqtt client. Then my application started to misbehave, looking into problems I found out that lwip needs for sure a core locking that is enabled by defaults in chibios port static_lwipopts.h but not implemented. If there is not so many processes running lwip runs for a while even without it, but adding frequent mqtt publish messages take it down.
Second is I think a bug in lwip port file sys_arch.c. Since lwip timer needs when calling sys_now() a u32_t counter. When using OSAL_ST_FREQUENCY other then exactly 1000 seems not to work, since it does not overflow on 32 bit boundary. Like me, using default OSAL_ST_FREQUENCY=10000 all lwip timers stop to work after 4.9 days. Causing various error on not clearing closed packets, DHCP and so on. It took me quite some time to wait 5 days for every change to show, until I realized it is sys ticks :)
I'm including my proposed changes.
Also it is needed to add to end of every project lwipopts.h
#if LWIP_TCPIP_CORE_LOCKING
void lwip_assert_core_locked(void);
#define LWIP_ASSERT_CORE_LOCKED() lwip_assert_core_locked();
And of course to start to use the LOCK_TCPIP_CORE / UNLOCK_TCPIP_CORE, like:
 LOCK_TCPIP_CORE();
  httpd_init();
  UNLOCK_TCPIP_CORE();
whenever the lwip function needs a core lock.
patch.zip
(1.95 KiB) Downloaded 201 times
Users browsing this forum: No registered users and 18 guests
